Old 2/18/06, 1:20 PM
jdegiorgio jdegiorgio is offline
Default Fogged window, then not fogged
Greetings, I did an inspection and checked the windows,two of them were heavily condensated, lots of moisture between the glass. Upon further inspection I noticed that the other windows had moisture between the glass. To make sure I even ran my finger on the glass surface to make sure that it was between.
I turned in my report as 4 fogged windows.I get called back because three of the windows did not have any moisture showing.I know what I saw the first time, but then re checking it was gone..Need to know whats going on
Thanks
Joe DeGiorgio
Compass Property Inspection
678-859-2992
</IMG>
Old 2/18/06, 1:46 PM
gbeaumont's Avatar
Default Re: Fogged window, then not fogged
Joe, the widows will show different ammounts of fogging dependent on temperature and RH differences inside and out, it is not unusual to see this specially as the windows heat up during the day.
I bet though that if you look carefully at the bottom seal that you can still see signs of moisture having been present.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 2/18/06, 1:48 PM
Gary, send me your number and I will call you,
Thanks,
Joe
Old 2/18/06, 2:12 PM
David P. Valley's Avatar
Thanks,
Joe
Gary who?
Old 2/18/06, 2:14 PM
Ted Allen Ted Allen is offline
Thanks
Joe DeGiorgio
678-859-2992
</IMG>
Did you take pictures of the windows in question?
Old 2/18/06, 2:30 PM
Yes I did, but you cannot see as well as when you just looked at it
Old 2/18/06, 2:37 PM
Ya, it's hard to take good pics of moisture inbetween panes, but it sometimes helps with callbacks.
Old 2/18/06, 2:42 PM
Doug Edwards,  CMI's Avatar
Try this next time:
www.nachi.org/forum/showthread.php?t=1737
Old 2/18/06, 2:44 PM
Originally Posted by dedwards
I like it!
Old 2/18/06, 2:49 PM
I am going to go back and try this....I will let you know what happens.
Thanks,
Joe
Old 2/18/06, 2:59 PM
You are welcome. Hope this helps. I usually wrap the ice in a piece of cloth or paper towel. I carry a couple of microfiber towels with me to mop up behind myself if I "discover" a leak or create one of my own. You can buy a bundle of 8 at Wally World for about $4. They are great cause they hold about a quart of water before you have to wring it out. Toss them in the laundry and viola like new. Great for drying up to after you've had your hands in someone's funky, nasty mess during inspections.
Old 2/18/06, 6:06 PM
scosta's Avatar
scosta scosta is offline
Please Note: scosta is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not sure I would try it, but I read somewhere another method of testing if the seal is broken is to press on the outside and inside of the glass and if the panes touch, the seal is broke. Anyone else hear or read of this method?
Steve
Old 2/18/06, 6:18 PM
NOt me. If its not when you start it might be when you finish.
Old 2/18/06, 6:43 PM
Steve
I honestly don't think you are going to get the two panes to touch each other. Maybe they'll touch when your hand finally goes through the window.
Old 2/18/06, 7:22 PM
Steve
I don't think I would try that.
Window well finishing rmuller Interior Inspections 7 5/10/07 9:11 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 4 4/23/07 8:31 AM
Replacing a double-paned window mmorgan Interior Inspections 24 3/2/06 11:09 PM
Window installation jmichalski Exterior Inspections 17 1/24/06 10:42 PM
