Stone was detaching all over the home foundation... and at the chimney too. That tall chimney. In most areas stones pulled loose and left the mortar on the block, or in the case of the foundation wall, on the concrete. The back side was an exception and a whole lower section had sheared off the concrete foundation wall taking mortar with it.
Over much of the work there was little or no mortar between stones, which were simply adhered to it (or not). I'm thinking mortar froze before it set up enough to withstand freezing temps. Qualified masonry contractor recommended. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Probably very well could of Kent.....but it's a nice looking house anyway.....
Was there any blue paint or blue carpeting inside? If so, maybe the mortar didn't freeze....................................... Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
This looks like more of a stone veneer rather than stones actually set in mortar. The stone is only applied to the backing mortar the stones are not set into the mortar and the stones not buttered between the stones. Freezing has most certainly aided in the damage.
| Masonry mortar types | mcyr | Structural Inspections | 11 | 11/11/07 11:36 PM |
| Holes in mortar | ccowles | Exterior Inspections | 11 | 8/7/07 11:30 PM |
| Brick and stone Mortar deteriorating | rjack1 | General Inspection Discussion | 5 | 4/11/07 12:50 PM |
| Frozen Heat Pump | hmcbride | Inspecting HVAC Systems | 10 | 2/2/07 10:18 PM |
| Historic Masonry Re-pointing: Repair or Ruination? | mbryan | Exterior Inspections | 4 | 2/21/06 10:49 PM |
