maitai11 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi,
Does anyone know what height the automatic reverse sensor should be? Usually I see it around 4", but recently I saw one at about 14" Thanks! Maitai |
Most manufacturers recommned no more than six inches above the floor. 14 inches is way to high. Recommend that it be lowered.
Thanks William!
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
The directions for a Craftsman opener were laying in the garage of a home I inspected the other day and they specified no more than eight inches high for the sensors.
John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
I write up anything over 6 inches from the floor.
6 inches is probably a good rule of thumb. I had a Genie screw drive opener installed in Jan. '07. The only thing I could find in the installation instructions is "Ensure that top of lenses are between 5"-6" above the floor".
All manufacturers are different. If you call out sensors that are mounted correctly according to the manufacturers specifications, you would have goofed. John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
Some manufacturers recommend the eye to be installed 12" from the floor, but some children have bodies that are thinner that 12 inches. So I simply call it out as a safety issue. I recall reading a tragic story about a little boy who was playing "Beat the door" and he didn't "Beat the door" and was squished to death. They investigated and found the sensers to be working fine but too high. |
I'll buy that!
jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
REcommend six inches.
I use 6". Anything higher would not see a childs bike laying down on it's side. Not to say that at 6" it will see the bike but, anythink higher won't for sure.
Anything lower then 6" and you have already crushed a person. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
| Installing GFCI in garage with no ground | cyezza | Electrical Inspections | 53 | 11/30/07 5:05 PM |
| Evaporative cooler in garage | chellickson | Inspecting HVAC Systems | 9 | 7/23/07 12:08 AM |
| Garage ceiling & door header | Al Barb | Interior Inspections | 7 | 3/27/07 12:07 PM |
| Garage Door Safety...No Reverse...Advice Please | gliebig | Exterior Inspections | 33 | 3/17/07 7:28 PM |
| Garage fire rated wall | jlybolt | Interior Inspections | 3 | 6/18/06 6:21 PM |
