Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 3/14/09, 10:55 AM
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Gas meter
Should the gas meter regulator be installed at least 3 feet away from the window?
Thanks! in advance for the input.
Old 3/14/09, 11:20 AM
Joe Funderburk, CMI's Avatar
Default Re: Gas meter
It's not supposed to leak. I don't think it would be a problem.
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/14/09, 12:16 PM
Thanks! Joe, it depends on the gas company. I found on the net requirements for PUGET SOUND ENERGY, the distance from a window is three feet.
Old 3/14/09, 12:18 PM
I'll have to confess to my wife I'm not as smart as I think I am. I just learned something new.
Naw...I won't tell her that.
Joe Funderburk, CMI
Old 3/14/09, 2:06 PM
Jeffrey R. Pope's Avatar
Actually, that IS supposed to leak. The diaphragm is a regulator and will allow gas to escape occasionally.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/14/09, 3:38 PM
That is correct.
Old 3/14/09, 5:48 PM
Gordon I. Kay Gordon I. Kay is offline
I disagree with you. The purpose of the vent is to allow the internal diaphram to breath. They leak when the diaphram ruptures.
You can install gas pipe from the vent to direct it away from the window to get your clearnaces.
Old 3/14/09, 6:28 PM
You're right Gordan. They will only leak if the diaphragm has ruptured.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/14/09, 7:12 PM
But they will also relieve some gas on occassion.
Old 3/14/09, 7:58 PM
Everything leaks, it all just depends on what leak rates are acceptable.
"Never ever threaten anyone in Camoflage"
Tim Wilson
"Not everyone follows the same path"
Governor Sanford, musings on the Appalachian Trail
Old 3/14/09, 8:48 PM
Most of these are equipped with a "vent limiting device," which is supposed to limit gas leakage (to within ANSI standards) in the event that the diaphragm has ruptured.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/14/09, 8:53 PM
Linas I. Dapkus's Avatar
Linas I. Dapkus Linas I. Dapkus is offline
My diaphram occasionally allows gas to escape but it depends on my diet.
Old 3/14/09, 9:36 PM
I've been waiting for that. Thanks for delivering Linus. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/14/09, 10:05 PM
Here in Illinois they installed gas meters inside the home years ago. One of the reasons they moved them to the exterior of the home is that the meter readers had to get inside the home to read the meter. If you weren't home they had to guesstimate. And then there was the mercury spill cleanup fiasco.
So as you can see Jeff, my little diaphram issues are nothing, they're a consequence of getting older.
Old 3/15/09, 3:40 PM
Jeff sounds like Linas needs a vent limiting device.
City electrical inspector says move the meter and panel cbottger Electrical 9 4/4/07 9:59 PM
Panel and Meter jwilliams7 Electrical 10 6/21/06 6:49 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
