Gotta like a spring-loaded roof hatch that isn't locked.
And a Sept 11 moment of silence. John Kogel www.allsafehome.ca |
As for the roof covering, it certainly looks shiney and new, but I'd question the lack of cant rail where the flat roof transitions up the parapet wall, that covering will crack along that interface. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thank you, sir. Good point, all the inboard structures have cant strips but there are none along the outer parapet wall. This may have been a Tar and Gravel roof originally, BTW. The drains are in depressed channels along the outer walls.
The important thing for my client buying the condo unit was, yes, the roof has been done. |
Do you expect to see cant strips on all flat roofs and do you write up missing cant strips if there are no seams at the transition area? I've done many commercial flat roofs in Boston and many do not have cant strips installed. They do continue with the rubber right up alongside the parapet with no seams involved. I don't have an issue with this. If you do, I'd like to hear your reasoning. |
no I don't write them up on some membrane roofs, it depends on the manufacturers installation instructions, however I write them up on all modified bitumen & T&G roofs, none of the ashalt based systems have the flexability to cope with the differential expansion between to roof and wall intersections, and they will fail quickly. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
EPDM is the only roofing material that will transition properly and fold at parapet without causing an issue. But... do that what another roofing material and you've got imminent issues. |
If there are any good links , going into detail on the above , I would appreciate them. |
Greg Bell Titusville, Fl 02111507 Serving Central Florida
Gotta keep up with that tech talk. |
Thought I would add that Gerry is correct in his assessment.
I install roof hatches like that pictured frequently. One thing I can't see is walkway pads to the equipment, and stepping out of the Hatchway. Usually, those are required, but not knowing this type of roof, it might not. The other safety item that is sometimes present in new hatchways, is a retractable hand pole that retracts in and out of the hatchway for going up or down the ladder. I don't know if you see that many of them. Below is a link from Firestone Rubber guard that shows all the flashing details for an EPDM Roof. http://www.firestonebpe.com/roofing/...%20ID%20H5.pdf This link will provide you all with flashing details for the Bitumen Products. As you can see, cant strips are required almost everywhere with this product. http://www.certainteed.com/NR/rdonly...odifiedbit.pdf http://www.certainteed.com/NR/rdonly...odifiedbit.pdf As Gerry said, without them, the expansion differiential is enough to make the joints crack and leak in the first year of their application. This link might be found useful for information also. http://www.rsimag.com/rsi/article/ar...il.jsp?id=6256 Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
From these two illustrations, a wide metal flashing is another possibility?
They may have torched-on right over the flashings. |
Dependant on the construction, there is sometimes no need to run the roofing membrane all the way to the top. This just adds to the cost due to redunancy in material serving the same purpose. Hope this helps. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Always follow the money. Hahaha Thanks Marcel. I have always wondered about that. |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
