Old 11/9/10, 9:12 AM
David C. Macy's Avatar
Default gutter covers/screens
If you were to recommend to a friend or install on your on home what gutter cover, screen would you advise or install?
I have experienced 2 types on my homes that are not very good.
Gutter Brush and Crane waterfall.
I like the simple metal screens that flip and clip and the aluminum/metal with lots of small holes. Most covers need maintenance and some are way to expense like gutter helmet and leaf guard.
The sponge types I feel are inferior as well, like the one on Nachi TV
Thanks for your opinions in advance
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/9/10, 10:00 AM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Default Re: gutter covers/screens
I have gutter covers like Leaf Guard. I get a lot of spill-over with heavy rains. Also, the splash guards at vallies get clogged with debris.
If you live in an area with pine trees, I wouldn't recommend the metal screens (too much maintenance). The pine needles always get trapped.
I'm beginning to think no guards are best, just pay someone to have them cleaned twice a year. I get leaves in the Fall and oak pollen tassles in the Spring .
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 11/9/10, 12:30 PM
No gutter guards will perform as they say they do....
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 11/9/10, 12:42 PM
Stephen W. Stanczyk's Avatar
It all depends on the type of trees around the home. Here in WA we have a majority of Douglas fir and their small needles but we also have large leaf maples, alders and cottonwood.
Leaf Guard does nothing for fir needles. Waste of money. They just follow the water around the curve and into the gutter and since these things are permanently connected, the gutters are just about impossible to clean.
Leaf Filters are the micro fine stainless steel sieve type filter. Nothing gets through and they work better in this rainy climate.
Tried a section of the sponge type above my shed door. Clogged after a single winter. Full of algae and moss.
My choice: Leaf Filter.
Stephen Stanczyk
Old 11/12/10, 8:11 PM
Bruce D. Pinel Bruce D. Pinel is offline
I only recommend things that I have first hand knowledge about. These have been on my house for 15 years. I have oaks, maples, white pine etc. around the house and have not cleaned gutters since. In fact, I think one of the consumer agencies gave them a high ranking.
S & B Services LLC
www.rihomeinspectionsbs.com
FHA/HUD Compliance Inspector S127
Old 11/12/10, 8:17 PM
Originally Posted by bpinel View Post
Attachment 40105
Fine Homebuilding didn't think much of the total cover things, rather they liked the ones you have pictured.
This is taken from their report recently...
The results of gutter guard testing and evaluation appears in the September, 2010 issue of Fine Homebuilding and confirms what I have long suspected; simple gutter screens work better at keeping leaves out and letting water into the gutter than the solid gutter caps with louvers along the front edge that are typically installed by roofing contractors. Heavy rains, common in this area, may run over the gutter shield (rather than into it) onto the ground where it may “pool” and cause structural damage to the foundation.
When you compare the price—$20 to $30 per linear foot (installed) for the solid gutter caps against gutter screens that can be had for 30 cents per foot—it’s a no-brainer. Even if you hire someone to install an inexpensive gutter screen you can save thousands of dollars; plus the screens work better.
Old 11/12/10, 8:20 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
None. I had a gutter machine with my construction business and found none work as well as cleaning your gutters once a year. Screens work as good as any I tried and are relatively cheap.
Daniel Henderson Daniel Henderson is offline
http://www.canadiantire.ca/AST/brows....jsp?locale=en
mike holmes has his own gutter guard! Im sure its the best on the market!
Old 11/12/10, 8:51 PM
Roy D. Cooke, Sr's Avatar
See many on my inspections None that I want on my home .
Old 11/12/10, 9:31 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is online now
I to have seen to many problems from installing gutter screens.
Maintenance free is not possible with gutters.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 11/12/10, 11:15 PM
Dominic J. Maricic's Avatar
Dominic J. Maricic Dominic J. Maricic is offline
Send a message via ICQ to dmaricic Send a message via AIM to dmaricic Send a message via MSN to dmaricic Send a message via Yahoo to dmaricic
Great timing as I need to take down mine and install new gutters. Thanks for the tips.
2008 InterNACHI Member and Innovator of the Year
HOME INSPECTOR PRO HOME INSPECTION SOFTWARE
NOW ONLY $499 ($15O OFF!!)
Easy to use, customizable Home Inspector Software that runs on Windows, Mac, Android & Linux
InterNACHI members receive 3 months of FREE home inspector website hosting
List yourself in our Home Inspector Directory Free
Watch our NACHI.TV Software & Search Engine Optimization videos!
Help@HomeInspectorPro.com
Old 11/12/10, 11:24 PM
Joseph Hagarty,  CMI's Avatar
I have yet to see any work effectively.
However....
Many Clients....
Comment to me
that gutter helmet is best
http://www.gutterhelmet.com/
Clients that have this system, praise this system to me
Those that have others....
generally complain about performance.
I have no personal experience...
just what clients tell me....
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 11/13/10, 12:10 AM
Mike Holmes has his own gutter grad in sure its the best on the market!
I have seen as I bet R.Cooke gutter guards that do not work.
Heavy rain they spill.
You sill have to clean out shingle granular
They clog with sleet
And tend to ice up if not cleaned out.
Just clean out after all the leaves are down and reset nails.
Old 11/13/10, 12:16 AM
Common Sense
what a concept
Joseph P. Hagarty
Phone: 610-399-3675
Old 11/13/10, 8:52 AM
I looked into the Gutter Helmet when it came out as a franchise. For the price of that system you can have your gutters cleaned twice a year. lol
Gutter Install krigler Exterior Inspections 6 5/25/10 5:49 PM
Gutter size calculation article bgromicko Exterior Inspections 0 2/25/10 2:34 PM
Gutter Guards mcyr Exterior Inspections 2 11/16/08 6:39 PM
Gutter advice dmacy Exterior Inspections 2 11/13/07 11:22 AM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
