How would one fix this problem. or is it even an issue, there are no end caps on these gutters. Also, the roof is interfering with the routing of the gutter.
Regards Gary Attachment 5044 "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com Last edited by nbhi; 7/8/08 at 9:09 AM.. |
[quote=nbhi]How would one fix this problem. or is it even an issue, there are no end caps on these gutters. Also, the roof is interfering with the routing of the gutter.
Regards Gary Put on end caps and install a down spout drop from the top gutter into the lower gutter. Roy Cooke |
It is a problem because the water flow from the gutter ends will wash off the protective granules from the shingles and they will age prematurely. The water flow needs to be rerouted some where else.
When you have a heavy rain you get a very large amount of water going over a very small section of the roof. As David said life can be cut 50%±. Roy Cooke |
Gary;
That was a good one. Never seen anything like it. Glad I live in an UN-innovated place. ha. ha. Takes someone special to devise a diverter like that. Marcel </IMG></IMG></IMG> |
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Like Roy and Adam said, you could cap them and extend downspouts, or even better, replace (or at least re-pitch) them away from this area to the downspouts. I also thought the overexposed shingles and the homemade ridge caps were a nice touch. What make situations like this even worse is that you usually see poor or non existent flashing at the fascias where the gutters currently dump.
jschulte is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are the gutters sloped down to that ridge so that the water is intended to go out of the gutter there and run down the roof? That is almost what it looks like to me, in which case I'd tell them to have the gutters rehung with downspouts located in a different location.
| Gutter advice | dmacy | Exterior Inspections | 2 | 11/13/07 11:22 AM |
| Proper gutter leader length? | gliebig | Exterior Inspections | 5 | 2/20/07 11:30 AM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 6:27 PM |
| NO Gutter on House...? | gbrasseur | Exterior Inspections | 10 | 11/13/06 9:38 AM |
| condensate line into gutter? | hspinnler | Inspecting HVAC Systems | 2 | 6/13/06 9:25 PM |
