Old 2/25/11, 6:21 PM
Mark Thiltgen Mark Thiltgen is offline
Default H clips
Looked at 1981 house today that had no H clips on sheathing, everything looked fine. Were they required in 1981 or did that come later?
Need a home inspection in Oklahoma? Check out InterNACHI's listing of Oklahoma certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/25/11, 6:42 PM
Jeffrey R. Jonas's Avatar
Default Re: H clips
Welcome to home inspecting in Minnesota! Was the home in the cities, or out laying areas? As you should be aware by now, every town you inspect in, has their own standards the AHJ holds to. It gets to the point that you have to contact every AHJ to find out what they required at any given time. The further from the cities you get, the worse it gets.
With that being said, the home is now 30 years old, and probably getting close to needing a new roof anyway (if original). I suspect it has been replaced once already. I would comment that the h-clips are not installed (not 'missing') and that they be installed when the roof is next replaced. At this point, no one is going to install h-clips because they are not installed. This equates to a full tear-off. Your client should be informed of this.
Old 2/25/11, 6:43 PM
Nick Gromicko's Avatar
Default Re: H clips
http://www.nachi.org/h-clips.htm
Find a Home Inspector
Old 2/25/11, 6:50 PM
Default Re: H clips
Mark,
I just checked your website. I see you are in St. Michael. (May want to change your location in the control panel). I do a lot of inspections in St. Michael, and h-clips are hit or miss there. I suspect they were not required there until the early 2000's from what I have seen.
Jeff
Old 2/25/11, 9:52 PM
Default Re: H clips
Thanks Jeff, I was in Brooklyn Park just off of 252. I pointed it out to client and like you said, the next new roof we'll get em in there! thanks
h clips nbhi Structural Inspections 23 5/8/09 10:48 PM
Lack of H clips and warranty poliner Exterior Inspections 16 2/2/08 4:51 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
HI nightmares in the news and other clips psiposs General Inspection Discussion 1 4/18/07 1:17 AM
