Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 11/24/07, 10:53 PM
Default Hail damage?
I thought this was blistering, now it looks like an older roof that's suffered hail damage because we've had some pretty good ones here in the last few years.
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 11/24/07, 10:58 PM
Dale Duffy's Avatar
Default Re: Hail damage?
Kenton,
Yes it does look like hail damage...and the shingles do appear old..I have not seen that stye here (anyway) in the last 30 years.
Old 11/24/07, 11:21 PM
Ed Fako's Avatar
Ed Fako Ed Fako is offline
Please Note: Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
Do you have any closer views of the multiple spots showing up.
It does look more like blistering from the far away view, but an older dried out shingle is more susceptible to hail damage, especially if there are any air pockets under them, as would be typical of the wind-lock shingles or on a re-roof.
Ed
Old 11/25/07, 1:49 AM
cbottger's Avatar
cbottger cbottger is offline
Ed
Being from the middle of the hail belt we call that hail damage
CMOR Thermography Certified Level 11 #2097
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
Professional Home Inspector State License # 130
Reporting system by Home Inspector Pro
Serving the State of Okla.
Old 11/25/07, 2:41 AM
Darrell B. Hadler's Avatar
Darrell B. Hadler Darrell B. Hadler is offline
We also get a lot of hail damage in our area as well...and that does not look like hail damage to me. It looks like blistering...hail will knock those granuals off the blistered areas easily though.
My vote...definately blistering.
Another clue would be to check the flashings and evestroughing and metal fascia for denting from the hail.
Darrell Hadler CMI
Five Star Home Inspections
Medicine Hat, AB. Canada
NACHI# 04111082 Cell phone# (403)502-3593
Inspected once . . . inspected right!
Old 11/25/07, 3:39 AM
Damage was not uniform throughout the roof, although these marks were scattered much less densly over most of the roof. No closer pictures, but this fist one shows the worst of it in the left foreground, I think it was North side. Second photo shows little damage but some granule loss and a little light damage.
EXPERT WITNESS
(303) 717-8940
(303) 258-8289
Old 11/25/07, 9:23 AM
Doug Edwards,  CMI's Avatar
Don't see any dents or dings in the metal roof vents.
Doug Edwards, CMI
Old 11/25/07, 10:18 AM
Barry Adair's Avatar
Haag has some useful free info on their site
http://www.haagengineering.com/ehail.../database.html
http://www.haagengineering.com/ehail...hailstorm.html
http://www.haagengineering.com/ehail...l/new_dmg.html
http://www.haagengineering.com/ehail...l/old_dmg.html
http://www.haageducation.com/pub_view.asp?productID=7
as with any inspection, assessment over the net from photos is most likely inaccurate, but Doug's observation is valid from the photos provided
Always retain the expertise of a qualified repairperson, one who has the skills and the knowledge related to their construction and installation and has received safety training to recognize and avoid the hazards involved, whenever repairs are noted
badair
ADAIR INSPECTION
972-487-5634
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 11/25/07, 10:22 AM
Mathew Hawley Mathew Hawley is offline
I was told that some bird ***** is very acidic and can damage shingles.
Old 11/25/07, 10:32 AM
So they say
http://www.pestbureau.com/services.htm
Damage to Roofs by Droppings
Bird droppings are very toxic and acidic in nature. They actually eat away at many substrates; especially shingle & tar based roofing materials. Droppings, which are allowed to accumulate on roofs, will eat into the material and deteriorate it, which will cause leaks. The life expectancy of a roof can be cut in half by just a light, but continuous application of bird droppings.
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/25/07, 1:20 PM
rcramer's Avatar
rcramer rcramer is offline
Hail damage will form a dent, even if the granules are in tact. If no dents in the soft metal, then it is not hail damage.......hail don't skip the soft metal. The only way to tell is to lift a tab and see if the hail caused damage to the mat of the shingle. Sometime you can see a spider crack around the inpact. Blistering will be raised, like a small volcano. Bird **** should be lick tested.......lol And then there is always the possibility of a manufactures defect.
Robert Cramer
Five Star Property Inspections
Your Best & Safest Choice
www.fivestarpi.com
1-877-378-2774
Old 11/25/07, 8:22 PM
cbottger's Avatar
If you look you can see hail dings in the upper right corner of the aluminum vent. We average at least one major hail storm every 5 years in my area; had one each of the last two years.
More HI'S in this state are sued for missing hail damage than any other item of an inspection. To many that won't walk the roof. I have observed every pattern of hail that your mind can imagine. Most of the bad storms arrive from the S.W and have observed roofs with dings on the west side an none on the east side. Sparse patterns, Heavy patterns Total destruction. You name it we get it.
From the pics above if you did not call that roof out you would be paying for a new roof in this State. Call it what ever you like but it is in need of replacement. In my report it would be listed as hail dings and would be refereed to a roofing contractor. BTW I have never paid for someone a new set of shingles and I don't intend to.
NACHI Member
Old 11/25/07, 8:38 PM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Exactly, I would call for replacement, and I always put possible Hail damage for them to try an insurance claim . We had a tornado come through here that was very bad, lots of hail,came through some people's drywall ceiling.. The hail was thinner and lighter in some areas with very light damage so I always put possible hail damage .
Old 11/26/07, 1:00 AM
Recommended evaluation by qualified roofing contractor due to damaged, possibly defective shingles.
EXPERT WITNESS
(303) 717-8940
(303) 258-8289
Old 11/26/07, 7:07 AM
Been trying to teach this to the roofers around here for years........they're not buying it.
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
hail damage ? bkelly1 Exterior 24 10/11/08 4:10 PM
Chicago area structural damage Anita Casey Structural 2 7/6/07 9:43 AM
How to prove tree damage to water main without digging. Jake Boen Plumbing 11 6/4/07 1:33 PM
Tenting and tile damage kswift General Inspection Discussion 9 11/27/06 11:22 AM
Hidden termite damage lprinzi Interior 15 11/9/06 9:20 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
