What is the hardboard clapboard siding called? I have seen it many times but always refer to it as hardboard siding, I guess by now I should be calling it by its real name.
Help. Thanks. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
Hardy Plank is the trade name for one brand of concrete fiber siding, there are numerous other brands that are similar.
These siding products manufactured with a wood grain finish, resemble conventional wood lap siding when installed. It is a man made product that has very few drawbacks. These sidings are concrete-based and extremely durable. They do not rot or deteriorate, and with proper installation and maintenance they appear to last without deterioration. The siding does need to be painted, it is not pre finished. |
Hi Chad,
I am very aware of the Hardy products. This is definately not a cement board type siding, it is the old press board type which does not like moisture. Thanks for the input. Scott Falvey Clear View Home Inspections, LLC Newbury, NH NACHI#05051292 www.clearviewhomeinspectionsllc.com |
i believe that product is just called hardboard. if I'm seeing what i think I'm seeing check this web link http://www.design-technology.org/hardboard.htm
Here is one of the best sites for helping identify the different hardboard sidings.
http://www.sidingsolutions.com/pages/SIDINGID.htm Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
Steve has sent you in the right direction for identifying perticular brands of siding, but it is worth mentioning that these type of materials are generically refered to as Composite Sidings. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Scott, I recognize the product from the late 60's and we just called it Masonite siding.
It was nailed on with spiral nails and would always mushroom the surface and wick water. In 1970, they came out with what they called color-lock siding made by Masonite and look the same, but with no face nailing. It had a plastic strip in the back that hooked the bottom to the previous course. This siding was not very good with maintaining color and the bottom of the siding over a few years would start to delaminate as well. Hope this helps. </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I don't identify brands in my report. I call the Hardy Plank type "hardboard siding" and the pressed cardboard "manufactured wood siding" in my reports.
Scott
I try to avoid using brand names, for trade type discription of materials. Hardie-Plank and Masonite are brand names that are typically used to describe all associated types of imitation/similar materials. I've been told, one could get in trouble for using improper/incorrect descriptions of materials, especially by Manuf's (Masonite and Others) in Class-Action lawsuits, that are pretty sensitive. |
When referring to hardie plank I call it what it is, Fiber Cement Siding, many companies make it, I think certainteed has a line now as well.
If you do not recognize a siding material and find a defect or installation problem it should be noted as such and move on. Don't speculate and don't guess as to what it is. Siding is siding, and whatever type it may be, if it is defective or installed wrong, call it out. I would have called it, and that is only because I have installed it and recognize it as a problem siding. Not everybody has had that privilege, so therefore report what you see. Marcel </IMG></IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
[quote=sfalvey]What is the hardboard clapboard siding called? I have seen it many times but always refer to it as hardboard siding, I guess by now I should be calling it by its real name.quote]
masonite is its manufactured name, (like tissue is known as kleenex) i guess "pressed wood" would be its generic name (as would tissue |
| Question about exposed styrofoam insulation. | mlong | Exterior Inspections | 9 | 12/21/07 9:33 AM |
| Asbestos | jlybolt | Exterior Inspections | 38 | 7/17/07 2:13 AM |
