Stick Frame Construction.
Hard Coat Stucco directly applied over OSB Substrate without flashing and/or vapor barrier installed on the OSB. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 2/18/08 at 4:34 PM.. |
"I create controversy whether they like it or not" |
#3 has no weep screed? Insufficient clearences, and was that gutter embedded into the stucco?
Gutters are installed prior to the installation of the stucco siding.
The heavy bead of gutter sealant between the gutter and the stucco should work Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 1/8/07 at 9:22 AM.. |
# 1, 2, 5, ....Lathe is applied directly to the OSB.
# 4.....Window trim is nailed directly to the OSB. Stucco applied up to the trim without flashing. In most of these homes, the interior window framwes and headers are deteriorated from water intrusuion. It has not visibly occurred within this home yet. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Bob Givens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hi Joseph,
http://www.toolbase.biz/Building-Sys...shing-products Maybe this will help from NAHB/TOOLBASE/ PATH Manufactured Flashings Bob Givens |
| Hard Coat Stucco / EIFS Trim | jhagarty | Exterior Inspections | 18 | 2/19/07 12:43 PM |
| Need to ID type of stucco | cdewitt | Exterior Inspections | 20 | 12/4/06 10:39 PM |
| Stucco course | badair | Inspection Education & Training | 2 | 11/21/06 5:51 PM |
| Wisconsin stucco problem | dnice | Exterior Inspections | 6 | 10/17/06 8:03 AM |
| Stucco Inspection | dlee2 | General Inspection Discussion | 7 | 4/3/06 8:17 PM |
