| Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera. |
What is the proper term fopr this type of roofing. Don't usually see it on residential I know that. And what about the alligatoring?
![]() ![]() Thanks. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network What we've got here is......failure......to communicate.....
| Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America) |
Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year Last edited by dduffy; 10/1/09 at 10:32 AM.. |
Sorry Dale, the link seems to be bad.
Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year |
I don't think that's what it is Dale. Doesn't look like poly. Looks like a hot mixture spread out over roof.
Odd they would install it in you're neck of the woods but it's common here. Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year |
Built-up roof would be my guess.
Alligatoring: Shrinkage cracking of the bituminous surface of built-up roofing, or the exposed surface of smooth-surfaced roofing, in which the loss of volatile oils and the oxidation of compounds under solar radiation produces a pattern of deep cracks with the scaly look of an alligator's hide. It occurs only in unsurfaced bitumen exposed to the weather. Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
I'm with Marcel on this, it is getting more and more unpopular in my area.
When a light aggregate is added to the top coat, it is also known as "pitch and gravel". |
Yeah, that is what it looks like, without the gravel. What you guys think of the condition?
Looks like it is at the end of its lifespan when it gets the alligatoring effect.
That is usually hot mopped on. They only last just over 10 years. |
Yeah, after looking at it Bob, it does look pretty weathered. Time for a new one, I suppose.
BUR
Surface asphalt cracks into large segments. This condition is found on smooth surface asphalt roofs. It is caused by the drying out of the exposed asphalt by the sun. If left unattended, this condition can develop into splits in the roof membrane, which in turn will allow water to enter the roofing system and then the interior of the building. Modified Bitumen Asphalt degradation is a growing concern. UV-rays oxidize the surface of the asphalt and produces a chalk-like residue. As plasticizers leach out of the asphalt, a modified bitumen or "mod bit" roof becomes brittle. Cracking and alligatoring inevitably follows, allowing water to penetrate the system causing blisters, and cracks. Seam failure inevitably follows causing leaks.A black modified bitumen roof absorbs a lot of the sun's heat in the summer. High temperatures and UV-rays accelerate asphalt degradation. I would have it evaluated by a Licensed Roofing Contractor to see if it has gone beyond salvagable repair and needs to be replaced. Sometimes the membrane has not cracked due to the alligatoring and can be salvaged by installing a top coat which would extend it's life to maybe another ten years. Cyr Home and Commercial Property Inspections IAC2 Certified NACHI04070211 http://co.nachi.org/inachiawards Commercial Builder CertainTeed Master Shingle Applicator Shingle Technology Ouellet Associaties Inc. http://www.oaconstruction.com/ |
Thanks for the quick help guys.
Never hurts to get estimates from a good flat roof outfit. |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 1:52 PM |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Services & Additional Topics | 12 | 2/13/08 12:33 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior | 9 | 2/15/07 2:19 AM |
