Old 6/30/08, 8:36 PM
mnahrgang's Avatar
Default What the heck?
Have any of you ever seen this? And if so, can you give me an explanation?
This is a typical box that would be used to trim around a wall opening or electrical box for vinyl siding.
Whats really weird is that the base plate is put on backwards. If you peak inside the holes, you will see the bare sheeting as well as some electrical wires.
(5 year old house. Seller didn't have a clue either.)
Mark Nahrgang
www.HeyMark.info
Old 6/30/08, 8:57 PM
Doug Edwards's Avatar
Default Re: What the heck?
lol. Yeah, it is basically a decorative backplate for an outside light fixture. It is so the typical round base is not straddling a couple of laps in the siding.
Old 6/30/08, 9:04 PM
If you look closely, you can see where you need to score the plastic pad for an octogon box. Installed some on my own house. Real nice for a light fixture.
Old 6/30/08, 9:06 PM
mnahrgang's Avatar
Yea, they look great when they are used properly.
I can't figure out the purpose... Hiding electrical wires.
BTW, there were two of these. One on either side of the house. One was really close to the AC shutoff, and the other was about 2 feet from the gas meter.
Mark Nahrgang
www.HeyMark.info
Old 6/30/08, 9:52 PM
The electricians never made it back to the house to finish these after they stubbed out some wire and the siders finished. Depending on location, they probably were for receptacles.
Larry Kage, CMI
231 929 3525
Old 6/30/08, 9:56 PM
mnahrgang's Avatar
Originally Posted by lkage
The electricians never made it back to the house to finish these after they stubbed out some wire and the siders finished. Depending on location, they could have been for receptacles or lights.
That's kind of what I was thinking, but they were on other houses in the sub., and where in a strange location for receptacles or lights. There were other lights and receptacles in normal places that were in appropriate locations. What would they have stubbed out 5 years ago that were never installed. Like I said, one was on one side of the house about 2 feet from the AC shutoff. The other was about 2 feet from the gas meter.
Mark Nahrgang
www.HeyMark.info
Old 6/30/08, 10:14 PM
Marc D. Shunk's Avatar
Banned
The sidewallers might have put them there to mount the AC disco's on, but the electrician didn't take the hint. Just a guess. They're a J-block, but if there's nothing behind them, it's just a guess what it might have been intended for.
Old 7/1/08, 7:01 AM
Frank J. Carey Frank J. Carey is offline
I am with Larry on this one. It is a universal trim box that was not used due to miscommunication or lack of returning workers.
Frank
Carey Inspection Solutions, LLC
Wilkes-Barre/ Scranton PA
Nachi ID -> 08022204
Frank@careyinspectpa.com
www.careyinspectpa.com
www.frankcareyconstruction.com
Old 7/1/08, 8:50 AM
mnahrgang's Avatar
There were wires inside. I couldn't tell if they were in a J-box or not or if they were capped/cut or anything. I could just barely see them, and the sheeting behind.
Here's some wider angle pics that give a better perspective on their locations.
Mark Nahrgang
www.HeyMark.info
Old 7/1/08, 9:58 AM
Judging from the locations, I would say it was intended for outside receptacles that just never got installed. When working on an HVAC outside unit it is nice to have electrical power right there withing reach for running some tools, equipment.
Old 7/1/08, 10:49 AM
Michael Larson's Avatar
These were a bit more obvious. They have been there 12 years.
ID:	22370   heck-612-galahad-059-small-.jpg.jpg
Michael Larson
Hudson, WI
[/I]
Old 7/1/08, 7:27 PM
Larry's assessment is correct. Here are a couple of photos of the same receptacle or light fixture pad for vinyl siding.
heck-dscn1486.jpg This is the way that the installers leave it. The cover is scored for knockouts using either a rectangular box case an octogon box.
heck-dscn1487.jpg The pad is made to remove the cover and install a pancake octogon box, for this case a wall fixture for an outside light.
Hope this helps.
Old 7/1/08, 7:42 PM
James F. McKee's Avatar
I'm with Larry and Doug on this one Mark....just need the electrician back for the outside receptacles....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 7/1/08, 8:58 PM
Carla Horne's Avatar
Carla Horne Carla Horne is offline
and, what is with the green sealer that appears to be a crack in the foundation?
Old 7/1/08, 9:04 PM
mnahrgang's Avatar
epoxy injection
Mark Nahrgang
www.HeyMark.info
One heck of nice Canadian site. gromicko Canadian Inspectors 30 2/8/08 12:23 PM
What the heck is this device!! dmacy Plumbing Inspections 11 3/18/07 9:18 AM
