Old 5/17/11, 8:02 PM
Lee Harless's Avatar
Lee Harless Lee Harless is offline
Default Help with Dryvit Exterior
I have a full home inspection on Thursday and the listing has the exterior as dryvit. I know there has been issues with this type of exterior and special training is needed to inspect it. I was wanting to know how all of you handled this type of exterior inspection and maybe some tips on how to write the comments in my report to cover myself. Thank you in advance for your help.
Lee Harless, Owner
Safe & Sound Inspection Services
Toll Free: 888-416-0230
Office: 304-521-1020
Cell: 304-412-5637
Fax: 304-840-0201
www.SSinspections.com
Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/17/11, 8:39 PM
Bob Elliott's Avatar
Default Re: Help with Dryvit Exterior
Determine if it is barrier or flashing based.
If barrier based notate any openings.
Describe what you see and recommend IR scan and EIFS specialist to follow up.
Go to exterior design Institute for a list of guys.
Old 5/17/11, 9:28 PM
Sean Fogarty's Avatar
Spend tommorrow and watch nachi tv on eifs.
Main points to look for:
Gutter ends, and lack of kickouts (espewcially ones that terminate into side walls)
lack of visible flashing or sections of stucco touching the shingles.
Touching the ground or concrete surfaces
lack of caulking around windows and doors
If you suspect water is behind it somewhere, the crawlspace is always the tell tale signs. I have found sections wet in the subfloor from leaking walls.
when all else fails recommend additional eifs inspection, especially if you find any, any, areas of concern.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Insulate Interior or Exterior of Basements mcyr General Inspection Discussion 4 7/24/07 8:27 PM
Your opinion needed jonofrey Exterior Inspections 24 2/1/07 12:10 AM
