Hello,
Inspection today. Came across a roof covering that I don't see very often. Are these mineral fiber shingles? Might they be a different type of asphalt shingle? Adding more information: The shingles were not brittle like cement. BTW, I looked at a copy of the invoice (1989) which said - "Roof with Wood appearance" That's it. Thanks in advance Last edited by ahannan; 9/30/08 at 7:53 PM.. |
Here are some more images
Look like they are a wood fiber pressed product put out by Masonite corp and named "Woodruf". It has a class action settlement against it.....see:
http://www.masoniteclaims.com/woodruf2/index.htm |
Sure does look ugly.
Thank you Brian! Looks like you've nailed it. Was not expecting a roof covering with a class action settlement Thank goodness I told the client that I was not familiar with the product and that I would have to do some research. Also, there was more info at : http://www.kinsella.com/masonite/pictureswood.shtml Thanks! |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Roof Covering | pmagrone | Exterior Inspections | 7 | 7/7/08 9:17 PM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
