Ideas on what I should say. It was solid when pound on. This was on a stick built home.
Gary Porter GLP's Home and Mold Inspections 321-239-0621 Certified Commercial Mold Inspector Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford Orange County, Seminole County, Volusia County, Osceola County www.homeandmoldinspections.com |
Gary,
Whats above that section? How old is it? Has there been an IR inspection? Is it the only spot on the house! What part of the house is it on? Garage wall? "I create controversy whether they like it or not" |
Built in 1956. Near the roof. No gutters. Rain Water is running down the wall
Do you have a wider angle picture of that part of the house not just that spot?
Whats on the other side of the wall? "I create controversy whether they like it or not" |
Real TARPAPER keeping the water out! No OSB/ vertical mulch! Not a one cote stucco job. "I create controversy whether they like it or not" |
Elastomeric paint properly applied could cosmetically fix it but it could also create new problems.
What direction does the wall face? "I create controversy whether they like it or not" |
If that house is frame built (and even if not) water can penetrate those cracks. There is a good chance that the stucco will need to be removed and replaced. It looks like it may be an impoper application - too much water added to the mix.
What were the specs for applying stucco in 1956?
To much water in the mix is by far not the only thing that can and does cause spider web cracking! "I create controversy whether they like it or not" |
From the looks of that picture, I would say the house has most likely repainted and stucco has probably been replaced or another layer has been added.
| What are some of the marketing ideas that worked | wdevries | Canadian Inspectors | 8 | 4/16/07 9:32 AM |
| Ideas Wanted | jmckenna1 | Miscellaneous Discussion for Inspectors | 18 | 2/2/07 6:42 PM |
