What is the best way to recognize EIFS vs regular stucco?
Michael L. Stanford Watch Dogs Home Inspectors ![]() NACHI Member User Name: mstanford Location: Washington Terrace, UT Posts: 5 What is the best way to identify EIFS vs regular stucco? Roy Cooke |
Easy... knock on it like you're knocking on a door. If your knuckles bleed its real stucco
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
And of it sounds hollow it is most likely EIFS.
Larry |
Guys - Quit jerking the guy around. Do like we do - drill a hole in it and look.
Or ask the neighborhood
}woodpeckers{ |
You guys really can't just look at it and tell?
Thats allright there is alot of smart people on this board who know more about the rest of the houses then I do! Last edited by cbrown1; 8/18/06 at 11:57 PM.. |
Sure, but how do you tell someone else how to do that on a BB. Like trying to describe an elephant to a blind man.
EIFS has no weep screed....1st check. EIFS has no metel screen.. Pull a plate.... See metel screen? There are some other ways , but this should do it. It really is easy once you know what to look for.... I had the hardest time with this, now I can see it a foot away.... |
Most of the hard cote stucco in the kansas city metro has no weepscreed either.
Weepscreed is overated. The caseing bead /66/stop/j-trim has holes in the back of it to let the water out also.
And it -weepscreed is ugly! And the corner beads crack out more when you use weepscreed. When 66/caseing bead is used the beads sit in a pocket and are less likely to crackout. When the caseing bead is folded around the corner and not cut. |
I am talking about "weep screed' with weep holes at the bottom of a hard coat system.... You cant see it. |
| EIFS question | tjansson | Exterior Inspections | 3 | 5/14/07 5:07 PM |
| EIFS bulge/cracks at top plate transition | kshepard | Exterior Inspections | 11 | 4/27/07 10:06 AM |
