LinkBack (3) Thread Tools
  3 links from elsewhere to this Post. Click to view. #1
Old 7/19/07, 8:00 PM
Gregory A. Liebig's Avatar
Gregory A. Liebig Gregory A. Liebig is offline
Default Is inadequate roof or attic ventilation a defect?
I've been running across many homes during the past several weeks that have ventilation issues. I use the 1 sq foot of free venting for every 300 sq feet of attic space. Usually the vents should be split 1/2 on the high side and 1/2 on the low side.
I was asked why inadequate venting is a "defect" and my response is
  1. Inadequate ventilation can significantly reduce the life of the roof due to the excessive heat
  2. Inadequate ventilation can lead to moisture build-up in the attic which can reduce the effectiveness of the insulation and/or lead to possible mold/mildew issues
Also, whenever I see a bathroom fan of kitchen fan directly into the attic, I call it out as a significant problem
I'm looking for some feedback on this issue. Is it a defect the seller should take care of or is it a maintenance item the home buyer needs to deal with?
Greg Liebig, Owner
Sheboygan Wisconsin Home Inspector
4-Square Home Inspections, LLC
Where Knowledge will put your Mind at Ease ©
Sheboygan, WI 53081
(920) 451-4646
www.sheboyganhomeinspector.com
www.4squarehi.com
Like Us on Facebook
Follow Us on Linked-In
Old 7/19/07, 8:35 PM
Dennis R. Goudreau Dennis R. Goudreau is offline
Default Re: Is inadequate roof or attic ventilation a defect?
correct on 1&2 & vent fan as for me I would just write it up in the report & leave it to the buyer & seller
Old 7/19/07, 8:42 PM
I guess I was a little unclear on how I would write it up. If I classify it as a "maintenance" item, the seller doesn't have to do anything. If I classify it as a "defect", then the buyer can ask for something to be done about it. That's the way it works in Wisconsin.
Greg Liebig, Owner
Sheboygan, WI 53081
(920) 451-4646
www.4squarehi.com
Like Us on Facebook
Old 7/19/07, 8:47 PM
phinsperger's Avatar
For a typical sloped roof attic you are correct. I would call it out as you would.
I know when you see the same thing many times you may start to second guess yourself.
One of the things I see in my area is a lot of century homes where there is no sofit (or low side) venting. Originally the houses would have had shakes on 1" roof deck boards. There was enough spaces through the boards and the shakes to allow ventilation. Now they have ashphalt shingles and often with an added layer of OSB. Sure the have static or ridge vents but noe means of providing intake air.
Old 7/19/07, 8:53 PM
AI would not write it as a maintenance item. To me maintenance means something that has to be done regularily. Once you install the proper venting that should be it.
Old 7/19/07, 8:55 PM
I would note the type of ventilation and recommend aditional venting if it needed it...that's all.
Larry Kage, CMI
231 929 3525
Old 7/20/07, 1:37 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
The idea of grease being vented into an attic bothers me.
Old 7/20/07, 2:16 AM
Inadequate ventilation in the attic is a defect, not a maintenance item.
So in Wisconsin, if your house was built correctly, and then you did absolutely no maintenance for 20 years, you would not be obliged to address any of the maintenance items identified on an inspection report? It seems silly that the state should get in the middle of the negotiation between the buyer and the seller.
Old 7/26/07, 1:27 PM
Karl E. Gerhauser's Avatar
Karl E. Gerhauser Karl E. Gerhauser is offline
Are you required by your state SOP to seperate defect and maintenance? We are not, and I don't, I just note all found items and bring major items to the summary , all noted items are up for negotiation.
Old 7/26/07, 3:21 PM
Unmoderated Guest
Attic ventilation requirements and good practice changed over the years, so that an attic that once represented the state of the art could be thought of as deficient by modern standards. If I were an inspector, I think I would write it up in something like that way, saying that it once might have been normal practice but that standards have changed, and thought might be given to upgrading to current standards. It's certainly worth noting, but my own humble opinion is that it shouldn't be noted in such a way as to force any party to take action.
Old 7/28/07, 4:16 AM
Good point, Richard. It's building science, it's looking at the home as a system and Greg, the people who want you to make the decision on who pays don't always get what they want. It appears that the laws of physics and the laws of Wisconsin may be in conflict here.
Our job as home inspectors is to describe the conditions as best we can. It may be handy for those who stand to benefit to have a title slapped on a certain condition, but conditions don't always lend themselves to handy legal descriptions. What are your options?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 7/28/07, 8:59 AM
David P. Valley's Avatar
I'm finding roof ventilation issues every day. Roofers are slapping on shingles in one day and not even bothering with vent installations whatsoever. Or they'll even install the ridge vent, but not even bother with the lower soffit/drip edge vent. I guess they consider this to be a Carpenter's job. I've even found many ridge vents that were installed at the ridgeline, but the plywood under this fake vent was not even cut back. These roofers are absolutely hilarious....
I see this defect so much, I had to design a web page for proper attic ventilation, in order to make it easier for my client's to comprehend proper attic ventilation. I simply note the defect, and add the link to their report.
Old 7/29/07, 5:07 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
David: Is the article on attic ventilation your own? Can I get your permission to tweak it and put it on my website?
Old 7/29/07, 6:44 AM
Roy D. Cooke, Sr's Avatar
http://www.buildingscience.com/bsc/
Read this one http://www.buildingscience.com/docum...bly/main_topic
............ Cookie
Old 7/29/07, 7:37 AM
Jimmy,
Yes, I designed that page myself. You can help yourself, but please re-configure the information a bit in order to make your web page content different from mine.
Roy,
Nice article but I like to see vented roof cavities (Ridge & Soffit) on many applications. The only unvented roof cavity I'd let roofers get away with (in my area) is the blown-in foam. One excellent foam insulation is Icynene.
And keep in mind, some roofing manufacturer's will not warranty their shingles with improper ventilation. Always check with the manufacturer's installation instructions.
Here's another nice read on attic ventilation.
http://www.airvent.com/pdf/literatur...ellingTips.pdf
LinkBacks (?)
LinkBack to this Thread: http://www.nachi.org/forum/f16/inadequate-roof-attic-ventilation-defect-19078/
Posted By For Type Date
Debating Attic Ventilation Pros and Cons - Contractor Talk - Professional Construction and Remodeling Forum This thread Refback 9/28/08 5:25 PM
should a gable dormer roof be vented? - JLC-Online Forums This thread Refback 9/18/08 6:19 AM
seal gable vents after ridge vent installed? - Contractor Talk - Professional Construction and Remodeling Forum This thread Refback 9/18/08 12:10 AM
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Spray Foam to the Rescue ? mcyr Structural Inspections 3 3/27/07 8:29 PM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
