Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 11/2/07, 4:20 PM
David C. Macy's Avatar
Default Inspecting a metal roof
Did my first inspection of a metal roof.
Any tips on inspecting this type of roof would be appreciated.
Can you walk on this surface.
How do you determine the age or life expectancy.
How long do the areas of penetration last until they leak.
Is this chimney covering stucco?
Thanks.
Roof was stated as 3 years old, there were no gutters, skylight leaked, no attic.
Old 11/2/07, 5:04 PM
rwand1 rwand1 is offline
Default Re: Inspecting a metal roof
I would not walk it.
Its a standing seam roof, not a cheap installation.
As the vendor for any information on date and warranties on the roof.
It is likely a lifetime roof, but refer to the manufactures information if available. This metal roof may last anywhere from 40 years on, dependent on installation, weather, maintenance..
As to penetrations they should be rubber boot type, that flexes, and allows expansion and contraction of the metal roofing. From the picture it looks like a big gap at bottom of the stack.
Flashings finishings should be complete and neat and tight. From your picture that area of the roof looks good to me.
However I am not crazy about the metal roofing as a chimney cap.
Cheers,
Old 11/2/07, 5:22 PM
bzimbelman bzimbelman is offline
Sure, call if you have other questions.
Yep.
I don't determine the age of these roofs, just the conditions. Blemishes, loose screws and bad caulking are the most common issues I find with them here. The one you are picturing appears to be seamless, i.e. no exposed screws to hold the seperate panels down. Each panel interlocks into the panel next to it, then is screwed in at the other side. The next panel covers this panels screws, and on and on and on.
There is also a version with exposed screws, should all have rubber grommets and they should not be loose or overtightened (rubber extends out of the screwhead). If either condition exists, then they will need to be fixed or it will allow water in.
Any penetration will need a boot and or some form of sealant to keep water out. I always recommend that all sealant be checked annually for cracks and repaired as needed.
Here you will see metal roofs on everything from flat to 9:12 pitch. Frequently here they are put over a composition or rolled roof with the old roof left on. Sometimes you can see the underlayment, other times you cannot.
The metal is not suppose to be water tight, i.e. the underlayment should be able to drain any liquid that gets under the metal to the drip edge and out somewhere. I always try to find evidence of some kind of underlayment, expecially if it's a low pitch roof and or there are multiple panels overlaped.
I'm sure there are things I'm missing, but I look at so many of them the problems just jump out at me by now
As for life expectancy, the gauge of metal and condition of the covering (yea, they say it's thru, but it's really baked on), will determine how long it will take for the metal to deteriorate. I see alot of tin roofs that are 40+ years old. Rusty as hell, but still water tight. They are about 1/2 as thick as this metal is, so I'm of the opinion that these will last a good long time. Manufactures say 50 I believe, but I tell my clients that the roof has not been in use long enough to verify the manufacture's claim of life expectancy.
Not sure I understand the question.
Not totally sure from the photo, but I would guess that it is.
Thanks.
Hope that helps!
Old 11/2/07, 7:51 PM
David P. Valley's Avatar
Inspecting metal roofs....You can absolutely walk the roof surface if it's considered safe to walk on. No snow or rain.
You should consider the following items when performing a roof inspection on a metal roof: A) panel corrosion B) loose fasteners at panel laps and C) seriously deflected panels.
An especially important area to inspect thoroughly is the system’s roof seams. The five primary components of the seam-fastened metal roof assembly are...
1) Horizontal panel seams
2) Vertical panel seams,
3) Panel fasteners,
4) Metal panels
5) Perimeter and penetration flashings.
Deterioration of one or more of these components is the most common cause of roof leakage. Horizontal seams occur where the bottom edge of a roof panel overlaps the top edge of the downslope panel. As panels expand and contract, sealants within these seams become brittle. Foot traffic, expansion, contraction and other forces deflect the panel seams, resulting in broken seals and open seams. Strong winds, negative building pressure or ice damming during periods of freezing and thawing might force water up the slope and into the building through these voids.
Vertical seams occur where the sides of adjacent panels overlap. Similar to horizontal seams, sealant deterioration and panel deflection also reduce a vertical seam’s integrity and allow water entry in conjunction with wind, negative building pressure, or ice damming.
Panel fasteners typically contain neoprene sealing washers to prevent water infiltration. Ultraviolet exposure and panel movement from expansion and contraction normally deteriorate these washers. The fastener holes also elongate from panel movement, and in some instances, the holes are larger than the washers. Overtightening fasteners during installation immediately damages the washers and increases their susceptibility to deterioration.
Loose, missing and rusted fasteners are common deficiencies, too. Steel panels, by their makeup, are susceptible to deterioration over time. Common deficiencies include rusting, kinking, puncturing and finish deterioration. If an inspector suspects leaks from panels’ end laps, make sure sealant is present and located in front of the fastener, not behind it.
Also, note if the sealant is cracked or dried. Inspect panel terminations at the eaves, ridges and valleys to ensure closure strips are in place. These strips are made of foam or rubber and fit under the panel to keep out water and animals. Also, inspect the trim pieces at the rakes to ensure they are sealed and fastened properly. Look for buckling or standing water at the laps of the panels, which indicates unusual movement within the system.
Perimeter and penetration flashings are common locations for leaks. The effects of panel movement are concentrated at these locations, thus accelerating deterioration of sealants, fasteners and other flashing components. Premature flashing problems can arise from poor design and installation. Quality workmanship and appropriate flashing material are vital to long-term flashing and roof performance.
While walking over the roof, you should make sure to inspect penetrations, the source of most leaks. you'll need to verify that the sealant is soft and pliable where the field and flashing meet. Fasteners should be tight, and neoprene washers should be in good shape, and not cracked or dried.
Metal systems typically are installed on a slope, so drainage is not a concern. But they usually drain via gutters, either exposed or concealed, so you should check gutters and downspouts to ensure they are free of debris and restrictions. If the roof slope is very shallow, you should look for ponding or restricted drainage in the roof field. Panel deflection sometimes can cause dips, which trap roof water.
Old 11/2/07, 8:11 PM
Thanks for the response.
House had no attic.
Only soffit vents that were painted. I would think the heat created would require additional ventilation.
Where was the roof venting?
I advised to obtain documentation as the roof was stated as 3 years & cost about 20K. Skylight leaked and ventilation was inadequate as it was painted.
Would of liked a thermal camera on this one!!!
Old 11/2/07, 8:29 PM
rcooke rcooke is offline
Banned for Violating COE
Please Note: rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like a ridge vent on this roof to me shows on right of chimney .
In our area steel roof frequently loose their snow in one fell swoop and off go the gutters .
Did one where the lady left her car nose into garage and the snow took out both fenders hood windshield rad grill..
She had a new Mercedes Wagon and I understand it was about $25,000:00 damage
We always recommend avalanche guards to try and control the snow.
Many steel roofs done in this area are not done properly .
I am not inpressed with steel roofs and would not have one cost in this area is about 3 times the cost of asphalt and most people move every 8 years.
I do not walk Steel roofs.
.................Cookie
Old 11/2/07, 8:48 PM
Linda J. Foster's Avatar
Linda J. Foster Linda J. Foster is offline
You have to be careful on steel roofing.
Early in morning, and in the afternoon as the dew starts to happen, it gets slick as all get-out. You don't want to exit the roof 'the fast way'. The landings are rather hard.
Linda
Old 11/2/07, 9:20 PM
David C.
Here are some photos from a homeowner who was taken advantage of by a roofer for $10k, on a century home.
See the difference quality makes?
inspecting-metal-roof-mvc-012s.jpg   inspecting-metal-roof-mvc-017s.jpg   inspecting-metal-roof-mvc-023s.jpg   inspecting-metal-roof-mvc-024s.jpg   inspecting-metal-roof-mvc-025s.jpg
Old 11/2/07, 9:24 PM
Thanks Ray very typical to my area too.
Some are even worse then this.
...Cookie
Old 11/2/07, 9:32 PM
David -
Much better explanation then mine.
I agreed with everything you said except the staement about them typically being installed on a slope. It's very common practice down here to install them in flat roof situations, either on higher end new construction or in the case where the builtup or rolled roof has reached the end of it's life.
Oh, and I never see sealent between panels, do you? Typical installation down here is a non water tight approach, where the underlayment (felt or previous roof or whatever) is used to catch any water that gets under the metal and drain it off to the gutters/drip edge. Are they installed to be water tight up there?
-- bz
Old 11/2/07, 11:56 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Panel fasteners typically contain neoprene sealing washers to prevent water infiltration. Ultraviolet exposure and panel movement from expansion and contraction normally deteriorate these washers. Overtightening fasteners during installation immediately damages the washers and increases their susceptibility to deterioration.
Very nice synopsis...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 11/3/07, 7:31 AM
Originally Posted by bzimbelman
David -
-- bz
Brian,
We don't have many metal roofs out here in Massachusetts. When I do find metal roofing I find that most of the panels are rolled with a male assembly along one edge and a female assembly along the opposite edge that create the standing seam when they are snapped into place. One side of the snap lock usually has a factory-applied sealant along the leading edge to prevent any water penetration. I'm not sure if this sealant is applied in the snow zones only.
Old 11/3/07, 9:52 AM
http://www.alutuff.com/installation/...b3-alutuff.pdf
Old 11/3/07, 1:08 PM
Brian,
David,
I think we are talking about the same thing. The standing seam (as you describe normally have a seal along the vertical edges along with the hidden screws. The others, which down here you can buy the panels at any HD, Lowes or other home improvement store normally do not have a seal along the vertical edge.
The instructions I've seen for both tell the home owner to have a weather barrier underneath, felt or otherwise. Many (most) roofers who install retrofits down here simply install these over their existing roofs and use that. Saves on tear off costs, and is usually as good as a new felt layer would be or better. Also keeps them from seeing the rotting sheathing, so they don't have to do anything about it
All the manufactures I've talked to say that these roofs just like comp shingled roofs are expected to allow a minimal amount of water into them and that water needs to be able to drain out somewhere. I've never seen any sealant where a higher panel sits over the top of a lower panel (horizontal seam) as that would stop water that had gotten in under the roof from draining out.
I was just checking to see if they were doing something differently up there.
I Frequently see these on barns and other buildings in ranchettes as well. On barns they frequently are over skip sheathing, usually every 3-4'. Make a he11 of a noise during a storm and the little woman is always amazed that their horses don't stay in the barns when it storms What rich people skimp on is always amazing.
-- bz
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior 6 10/13/07 9:10 AM
Ice Gaurd membrane dmacy Exterior 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior 9 2/15/07 2:19 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
