50 year old house...
Is this mineral wool? It was extremely crumbly. I'm used to seeing white, but didn't know if it came in other colors. This was pretty packed down, and wasn't soft and fluffy like most insulation (maybe deteriorated with age?). (It was fibrous, but not at all like cellulose.) I suppose fiberglass could be an option too... Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like it could be older fiberglass loose fill...
take a look here http://inspectapedia.com/interiors/I...tion_Guide.htm Wendell F. Cook, CMI
271 Washington Blvd. Hudson, NY 12534 518-828-0191 www.homeinspectionshudson.com wfchomeinspections@verizon.net Instructor, C.A.T.S. of Albany Home Inspection School "Life is what happens to you while you're busy making other plans." John Lennon |
Does fiberglass get "crumbly" with age? Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
I always see mineral a brownish color around here real dense not fluffy it is made to fit between steel studs and i have seen guys put it up where the corrugated floor on a commercial building meet the sheet rock and then they spray fire proofing on it
http://en.wikipedia.org/wiki/Mineral_wool |
That's rock (mineral) wool. It becomes crumbly (dry) with age.
Christopher Currins Certified, Licensed Proudly serving the Illinois Metro-East Illinois Home Inspector Top 5 Tasks for January |
That makes some sense. This was only marginally similar to fiberglass.
Thanks guys! Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
| Insulating Your House from CMHC | mkyriacou | Canadian Inspectors | 10 | 2/14/10 4:50 PM |
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 11:49 PM |
| Thermal insulation research for sustainable construction | mkyriacou | Green Building Inspections | 0 | 3/3/09 12:04 AM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 2:30 PM |
