It occurs to me that joist hangers that are installed at a cantilevered rim joist should either be installed "upside down", or should be replaced by a different piece of hardware. I can't find anything that addresses this type of installation on the Simpson website. Does anyone care to share their thoughts on the subject?
This particular joist hanger is a double sheer design, but the installer used 1.5" nails that don't even pentrate into the rim joist. Oops. |
On cantilevered floor joists with double rim joists, I always installed the joist hangers upside down. It wasn't such a big deal with a single rim joist and 2x6 wall above.
This is a deck application, and the guardrail is bolted to the rim joist. The rail felt fairly solid in spite of the improper fasteners, though I don't like the gaps between the joists and the joist hanger cradles.
The pic you posted looks fine and it is kind of hard to tell from Michigan but you can recommend adding fasteners if you think they're needed.
Paul,
I talked to the engineers at Simpson and they say their hangers have been tested and can be used upside down as long as a private engineer has calculated the design loads for the specific job at hand. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
I do not see the need for any of those joist hangers right side up or upside down.
Band/Rim Joist: Band joists, also sometimes called rim joists, are just joists at either the side or end of the deck. There's nothing special about them. In fact, unless you've got stairs attached to one of them, band/rim joists only have to carry a fraction of the load that the regular floor joists do. The rim joist is also referred to as part of the band joists. The band joists are the ledger, header and rim (side) joists as a whole. The rim joist is often the member that the railing posts are attached to for support. You will need to give extra support to the rim joist at these junctions. By installing bridging next to an inset post or behind an outset post you will ad a great deal of strength to the bottom of the rim joist. This will keep the railing firm. You should be securing the rim joist at each end. It will not be possible to use a joist hanger at this connection. You should be nailing your frame together with 16 penny hot dip galvanized nails. Each end of your rim joist should have at least 5 nails. Most builders screw a 6” inside corner bracket inside the frame. This should keep the rim joist from loosening away from the frame. When it comes to installing the rail post, addittional bridging and reiforcement will be required to help the band joist support it. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
If the cantelever is installed correctly, only 1/3 of the span will be in the cantelever, the rest will be toward the interior. The interior portion of the joists is more likely to carry a heavy load.
If someone happened to place a waterbed on those joists, so that it rested on the joists but it didn't quite bear on the framing member to which the joists were nailed...and it was directly above your bed... which way would you like to see those hangers installed? But as to making a call... As Barry said, shouldn't make much difference as long as all the nail holes are filled with the proper fasteners (cometimes hard to confirm). Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
I am assuming due to a small picture or the whole picture only seen in the eyes of the beholder, that the cantilever is 2' or less and has a typical rail post attachment. This picture seems to indicate a bolt through the band joist that I assume is the rail post and has not been reinforce to withstand the lateral pressures that may be exerted on them and the rotation may cause failure even with this inappropriate hanger. If this is indeed a exterior deck, than the band/rim joist would only be an aesthetics and provide a closure at the end of the deck joist. I might be looking at this all wrong, I am not sure but feel free to let me know. Marcel </IMG> LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Those hangars are not supporting the cantilevered rim joist, they are fastened to one(and are installed correctly). I would be more concerned with how many joist are cantilevered and by how far they extend outside of the structure. How big is the deck? Do you have any full photos?
This may help to clear up some of the previous information posted.
http://buildingcodes.jocogov.org/doc...eck%20Book.pdf Here's the joist hangers at a cantilevered section of deck/carport I questioned Simpson about. ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 4/28/08 at 8:01 AM.. |
Marcel,
Just about everything you said in your last post was correct. It is a short cantilever, and the rail post is bolted to the rim joist. There is no additional framing to support the rail posts. For those of you who believe that the hangers are installed correctly, I don't think you have wrapped your mind around where the forces are exerted on a cantilevered rim. The joist is not hung off the rim, the rim is hung off the joist. The joist saddle would therefore need to be at the top of the joist for it to do any good. Also, it is important to use 3" nails (either 10D common or 16D sinker, see pic) in a double sheer hanger for the angled nails. The 1.5" nails that were used (confirmed visually at the inspection) do not penetrate into the rim joist at all! This installation maybe has about 20% of the strength it would have if installed correctly. Is it enough? Like I said, the rail felt firm but I don't like the way in looks. Last edited by pdickerson; 8/17/07 at 8:11 PM.. |
Ooops! You're right Marcel, my bad. We're looking at the exterior rim joist for an exteror deck... part of the cantelever. Bolting the handrail post to the rim like that will definitely loosen it over time. Quality issue rather than defect the way I see it. Poor design, mostly. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is Code violation to not have joist hangers at the ends of joists where they butt against a rim joist. |
| Pipe hangers | Ian Gills | Plumbing Inspections | 4 | 5/11/07 5:17 PM |
| Frost, Ice, & Condensation @ RIM JOIST | Sean M. Jeric | Inspecting HVAC Systems | 4 | 2/5/07 6:56 PM |
| Cantilevered Joists | Steven Brewster | Structural Inspections | 13 | 5/9/06 7:32 PM |
