Old 12/30/07, 11:40 AM
Barry Adair's Avatar
Default Just doesn't want to stay up
Always look up
This previously fallen and repaired arch section is in a failing foundation location 17' up at the front entryway
Disclosure said it has been repaired 3 times along with the foundation
4 year old house...they need better repair contractors
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/30/07, 11:43 AM
Default Re: Just doesn't want to stay up
Don't they make stretchier mortar for those situations?
Larry Kage, CMI
231 929 3525
Old 12/30/07, 1:41 PM
s t r e t c h i e r
Like that word can I use it for my reports...
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/30/07, 3:54 PM
Originally Posted by badair
s t r e t c h i e r
Just let me know if ya use it up, okay?
Larry Kage, CMI
231 929 3525
Old 12/30/07, 6:51 PM
William J. Decker's Avatar
How did you write it? "Improperly repaired"?
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 12/30/07, 7:25 PM
Roy D. Cooke, Sr's Avatar
They forgot to add the glue remind them for next time to use enough glue ..
...Cookie
</IMG>
Old 12/30/07, 7:26 PM
I'm guessing you're asking about Barry's post #1...
Mortar joint separating...
Larry Kage, CMI
231 929 3525
Old 12/30/07, 7:32 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
Now there is a classic example of the difference between a mason and a brick layer. Does no one know how to make a keystone anymore?
Larry
Old 12/30/07, 7:33 PM
Bill Mullen Bill Mullen is offline
Please Note: Bill Mullen is a non-member guest and is in no way affiliated with InterNACHI or its members.
Oh crap. When I saw the thread title I thought I could get some cheap Viagra here.
The search continues !!!!
Bill Mullen
Old 12/30/07, 7:42 PM
Originally Posted by dedwards
Write what it is; mortar joint failure/separating. "Improperly repaired" might be an assumption and does not address the issue. Could be a product failure. We all tend to overthink the problems at times.
Cheap, non-professional contractors generally use cheap and non-professional materials. My point stands.
Will Decker, CMI
Old 12/30/07, 7:44 PM
Bill Mullen
Your problem, Bill. Can you say "thread drift".
Too much information.
Hope this helps;
Will Decker, CMI
Old 12/30/07, 7:45 PM
Larry
And a clear indication of people wanting the best work, but not being willing to pay for it.
That's why I recommend repair by a licensed and insured contractor.
If they mess up, their insurance pays for it.
Simple, really.
Will Decker, CMI
Old 12/30/07, 8:37 PM
Banned
Someone mentioned a "keystone (brick)" previously and may be on the right track! A properly designed arch uses gravity to its advantage....if the supporting bases are solid, the above loads force the arch units together. Why is this arch failing? Are either of the two outer support walls/columns moving outward to allow the settlement/separation we see? Or is this simply decorative with no load at all....in which case, maybe enough crazy glue may stick it to the upper load carrying beam or structure!!!!! LOL
Old 1/1/08, 9:37 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Just how did those Romans do it without Super Gorilla Glue???
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 1/4/08, 12:05 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Falling arches? Maybe they should get a pediatrist instead of hiring the same stooges over and over again.
InspectorsJournal.com - GOOGLE DROPPING NACHI RANK??? jwatts1 Miscellaneous Discussion for Inspectors 19 7/5/07 3:53 PM
POLL- Paul Stay In The Electrical Forum pabernathy Miscellaneous Discussion for Inspectors 40 12/19/06 12:05 PM
single lever faucet won't stay open toddn Plumbing Inspections 1 11/21/06 9:51 PM
Stay tuned in Ontario clawrenson Canadian Inspectors 22 11/3/06 11:14 PM
