Old 1/14/10, 10:41 PM
Joe Funderburk, CMI's Avatar
Question Kickout flashing needed???
Is this enough roof area to be concerned about the lack of kickout flashing?
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Need a home inspection in Georgia? Check out InterNACHI's listing of Georgia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/14/10, 11:41 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Default Re: Kickout flashing needed???
In my area I would say yes Joe. Because if the water overshoots that it will be heading right for the lower window and shutter, and then possibly freeze.
In your area, the water itself could be enough to cause problems. I would say yeah, can't hurt.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 1/14/10, 11:59 PM
Christopher Currins's Avatar
I'd be more concerned with all of the water that will be pouring out of the 2nd level downspout. It is hard to be sure viewing only this pic. but it looks like it doesn't need to be there and will cause more harm than good.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 1/15/10, 3:28 AM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
The downspout is from an upper gutter and needs to be there. However, the gutter installation is poor. Even with a kick-out or other diverter, the volume of water from the upper roof could be too much for the lower gutter. I see these kinds of installations a lot when doing condominiums. The problem is that the architect should have considered the roof drainage when designing the roofs. But, they often do not particularly for complex roofs.
One of those things that I check during home inspections are water stains on the gutters. If they are present, then you know the gutters probably have had a chronic overflow problem. You can also verify that finding by verifying whether soil erosion is present below that area. The location of the water stains along the gutter can also tell you what kind of problem might be present. For example, stains near a downspout could indicate a plugged downspout. Those along the middle could indicate an improperly sloped gutter. Those along the bottom back edge of the gutter could indicate water flow between the gutter and fascia. I think you get the idea.
I have come to believe that gutter and downspout design is as much an art as science. The problem is that not a lot of both seem to be present in the industry. The design is often left up to the installer, and the installer is worried more about getting in the low bid than making sure the design is right. I wonder how many actually know about the design equations that are available on-line.
Old 1/15/10, 8:37 AM
You mostly see kickouts on an exterior cladding, not brick, unlike other materials such as vinyl siding, stucco, hardboard siding etc, brick is going to have a 1/2 - 1 inch space between it and the wall sheathing; any moisture that collects on the inside will run down over a moisture barrier and make its way through weep holes, obviously there are concerns when you have a design whereby the roof is dumping water directly against the brick itself; this configuration is not one of them.
The area that is of greater concern would be the area between the fascia and brick wall.......the picture does not provide enough info.
I would have looked at how they step flashed the bottom including behind the side of the gutter paying particular attention to the first step flashing before making the call.
In regards to the gutter if there is another down spout to the left of of picture it too would be fine...... without seeing the pitch and the amount of surface area the gutters are collecting, it would be premature to say for sure.
Did you walk the roof and if so, do you have any better pictures.
Jeff
Old 1/15/10, 12:25 PM
Carl A. Brown's Avatar
Yes it does.
Old 1/15/10, 12:40 PM
Would it be safe to say that the brick layer did the job
right?
Old 1/15/10, 12:55 PM
No diverter would normally be installed in this type of construction.
If the brick hasn't been sealed, it won't be anyworse than the driven rain on the rest of the brick facade'
I do agree with the gutter, it should have been in the corner with the discharge run down to the lower gutter if prevent roof shingle erosion and staining.
Old 1/15/10, 12:56 PM
Nick Gromicko's Avatar
More on kickout flashing.
Find a Home Inspector
Old 1/15/10, 1:22 PM
Agree with Marcel.
Not typically needed because there is nothing to "kick out".
http://www.mim-online.org/Residentia...shGuide-08.pdf
see if page 10 is helpful...
Larry Kage, CMI
231 929 3525
Old 1/15/10, 1:55 PM
With the Bob's kickout diverter's you can also keep the gutter out away from the wall.
Old 1/15/10, 2:23 PM
I have seen several around here where the roofer was on the job before the bricklayer and roofed all the way to the wall sheathing, then the bricklayer laid the brick right on the roof.
Old 1/15/10, 2:33 PM
Backwards arse huh!
Old 1/15/10, 4:43 PM
Bob Elliott's Avatar
Originally Posted by lkage View Post
Agree with Marcel.
Good point.
Does anyone feel a "kick out" is needed on brick veneer if it has proper flashing ?
Old 1/15/10, 5:21 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Is this a proper KICKOUT flashing for stucco?
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Ledger Board Flashing jevans Exterior Inspections 15 7/2/09 11:42 PM
Please post questions about anything having to do with roofing kshepard Exterior Inspections 165 6/17/09 12:47 PM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 11:54 PM
Kickout flashing Problem? Bonnie Gillis Exterior Inspections 10 12/27/06 10:37 PM
Diverter / brick flashing detail needed srowe Exterior Inspections 3 12/20/06 8:02 PM
