Old 6/23/06, 2:09 PM
Carl A. Brown's Avatar
Default kickouts
Hey everybody be on the lookout for these. Or even metal ones with all claddings not just stucco.
http://www.dryflekt.com/
Old 6/23/06, 2:36 PM
Dale Duffy's Avatar
Default Re: kickouts
Old 6/23/06, 3:03 PM
Dale Duffy's Avatar
Old 6/23/06, 4:16 PM
Dale Duffy's Avatar
Kick-Out flashing didn't help this homeowner.
Old 6/23/06, 4:22 PM
Dale Duffy's Avatar
Old 6/23/06, 7:11 PM
Dale - FRom the photo's it didn't look like a properly sized or installed KO.
Old 6/23/06, 8:55 PM
Steve Boozer Steve Boozer is offline
Please Note: Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kick-outs are so important. Once the water enters the wall cavity it has no ventilation to let the moisture escape,which causes major damage. The defleckt product is once piece which is good. My only complaint is they're so big they look ugly sticking out from the stucco unless you trim them down. Dales first pic showed no kick-out, the second pic had a host of problems besides the kick-out and appeared to have a copper metal roof above which should have a soldered copper kick-out. The third pic (apparently below this area) had window problems possibly along with a kick-out flashing problem above it. Is this the way you other guys see it?
Old 6/23/06, 9:12 PM
Dale Duffy's Avatar
Old 6/23/06, 11:10 PM
Steve'
those kickouts seem large but they can be trimed down alot easier then streching them. It seems fruitless when the step flashing only goes up the wall 2.5 or 3 inches. And when a retro is being done most of the time the stucco is so thin its is kinda tuff to use them. It is a very good product and would be best installed at the time the roofers are there. After all it is part of their installation.
Old 6/23/06, 11:41 PM
Dale Duffy's Avatar
Originally Posted by cbrown1
Steve'
What about the tar paper in back of the nail-fins?.........
Old 6/23/06, 11:52 PM
You mean where the installed the window and on the bottom nail fin the paper was over the fin instead of under it creating a funnel.
Old 6/24/06, 12:00 AM
Dale Duffy's Avatar
Thats what I'm talking about....
Seems to usually make a difference regarding water intrusion.....
Old 6/24/06, 12:03 AM
Dale Duffy's Avatar
This is nice.
Old 6/24/06, 1:12 PM
Just curious. Do you guys have any diagrams on how to run vinyl siding window trim? I have never understood how it can't leak the way I see it done. Always looks like it would trap water big time.
Old 6/24/06, 3:01 PM
Dale Duffy's Avatar
Here Steve.
http://www.certainteed.com/NR/rdonly.../0/CTS205b.pdf
