1981 build wood siding and porch cover addition transition. should counterflashing be installed and exposed?
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Yes, Where dose the water go? Or end up I should say?
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Is it base and ctr flashing? Does the flashing need to be exposed 1" min?
You mean leaves are not considered flashing.
It is not a deck but the same kind of flashing would help!
http://www.flash.org/resources/files/HGCC_Fact23.pdf "I create controversy whether they like it or not" |
| Window flashing -- | lfoster | Exterior Inspections | 43 | 10/28/07 9:47 PM |
| no flashing; no inspection | Leanne Jowers | Exterior Inspections | 97 | 5/9/07 12:11 PM |
| exposed step flashing | Rafael | Exterior Inspections | 9 | 5/8/06 12:25 AM |
| Step flashing at vertical wall? | jlybolt | Exterior Inspections | 31 | 2/12/06 11:40 AM |
