Brenda is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am building a home in Indiana and have a small leakage problem in one room on the main floor. The home is a 2 story, fully sided and roofed with gutters, but during severe storms when the rain whips horizontally, some water gets into a corner room on the main floor. It is not coming in through the window area, but below a window and dribbling down the wall and onto the floor. There is a porch roof attached to the front side of this room, but the leaking is occuring on the wall attached to the back of this roof. There is no aluminum drip edge on the house and the roof sheathing is visible and exposed between the fascia and the shingles. I am having someone install a drip edge, but is that likely the cause of the water alone, or could there be other issues here? I had an Illinois roofer and an Indiana siding/fascia/soffit company and each claimed the other was supposed to do the drip edge. Apparently in Illinois the siding people do the drip edge and in Indiana the roofer does it, so no one did it in this case and I only just discovered this. We are to the point of having the flooring and cabinets installed and the final grade has been done, so we are very close to occupancy, but obviously this has to be addressed ASAP. I did have inspections done each time we did a draw with our bank, but this problem was never noted. Any suggestions? Thanks much!
Any kind of moisture barrier used?
Yes, there is Tyvek wrap on the exterior of the house
Is it over the flashing or under them? Do you have any pictures?
I don't know the answer to your flashing question, but I can get some pictures later today and post them. I have some pictures, but they aren't close enough for you to be able to see the details well enough.
These pictures might help...
![]() ![]() ![]() ![]() ![]() These aren't terribly close up for pictures, but they are something, until I can get closer images later today. It isn't pictured, but there was tar paper put down before the roofing shingles went on the house. |
When the faux stone was put on did they put on another layer of moisture barrier?
It looks like the flashing at the roof,wall intersection is over the housewrap. Last edited by cbrown1; 6/12/06 at 12:38 PM.. |
Did they install waterproofing flashing around the top & down the side of the windows & around the sill before installing the windows & siding?
If the flashing is over the tyvek, is that a bad thing? |
It then becomes a funnel. If it is tyvek it is bad for it to come in contact with cement. Or so I have been told.
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
It helps allot to give a pic of the specific problem area. But lack of drip edge is not the problem. But I can promise you 100 percent the back of the chimney flashing will be done wrong and will leak. If so the damage will be severe over time.
BTW, the big pics you posted are great since I'm on high speed!!!!!!!!! Some users complain if they're on dial up which can forever to view, but big pics are the only way to go. So I guess if a big pic is worth a thousand words, a little pic is only worth 100.
What did they use on the chimney for moisture barrier? Did the run the stone all the way down on the roof?
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 5 | 3/25/07 10:41 PM |
| Asphalt shingle overhang at drip edge | jcampbell | Exterior Inspections | 8 | 11/10/06 7:48 PM |
