Old 1/30/07, 7:52 AM
Carl A. Brown's Avatar
Thumbs up Ladder saftey tips!!
Do not try this at home or anywhere else!
http://www.i-am-bored.com/bored_link.cfm?link_id=21716
Old 1/30/07, 7:57 AM
tneumann's Avatar
tneumann tneumann is offline
Default Re: Ladder saftey tips!!
Now how about some real ladder safety...
I stole this article from RR......
http://www.aeinspections.homestead.c...etyARTICLE.pdf
Old 1/30/07, 7:59 AM
That was real!!
Old 1/30/07, 1:54 PM
Tony,
How about this one?
http://osha.gov/pls/oshaweb/searchresults.category?p_text=ladders&p_title=&p_s tatus=CURRENT
Old 1/30/07, 2:37 PM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Can't remember who I stole this link from but I ordered one and IMO it is fantastic!
http://www.buyladder-max.com/
Old 1/30/07, 8:21 PM
Carl;
That was pretty cool.
Thanks.
Old 1/30/07, 8:30 PM
That is pretty nice.
Problem I have had in the past 30 + years is trying to adapt new workers with idiot proof methods in safety and work methods.
The barrier I am up against is the fact that the minute I realize I have perfected a method that is idiot proof, and is working fine for a while, well I'll be damned, another idiot shows up.
Can't win. ha. ha.
Marcel
</IMG></IMG>
Old 1/31/07, 3:55 AM
Russel Ray's Avatar
Darwin says that even idiots adapt to survive.
Old 1/31/07, 6:48 AM
mthomas2 mthomas2 is offline
Chris,
I posted about the Ladder-Max a while back - don't know if it was my post you saw, but it indeed does add a LOT of lateral stability while keeping your weight off the gutters.
Recently, I've also been experimenting with a pair of these:
http://bestmaterials.com/detail.aspx?ID=15566
they also work very well (especially if you if you can tie off to a gutter spike or similar) as there is no lateral force on the ladder at all - you just "step through the ladder" onto the roof. and they can be used with “flat” or low-pitched roof where the Ladder-Max cannot.
I think the "perfect" solution would be some combination of these approaches, but IMO either is much safer than a ladder alone when moving between the ladder and the roof.
The other change I've made is to install these on my extension ladders:
http://www.globalwholesalersinc.com/quick_connect.htm
so I'm always set up to deal with an uneven surface.
Over the last year I've ended up spending around $800 on ladder accessories. and really wondered each time I ordered one if it was worthwhile.
But now that I’m set up as I am, I wish I had done it from day one - IMO being able to easily deal with uneven ground and having some additional control of ladder movement at the top it makes night-and-day difference in safety (and my confidence) even if I'm only inspecting a roof from the eaves due to pitch or weather conditions.
I'd also put in another plug for "Cougar Paw" shoes - though I recently had an unpleasant experience when moving from the south to the north side of a "clear" roof in freezing weather
Though neither showed any visible sign of moisture, the north side was pretty slick, and the grip of the CPs on the south side had perhaps made me a bit over-confident as I moved over the ridge - OTOH the CP's remaining grip may have saved me from a nasty fall. In any case, lesson learned.
Old 1/31/07, 8:38 AM
bandag bandag is offline
Please Note: bandag is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yeah, I have seen these pics on another post somewhere. That guy standing in the water drilling could have been used for a new 3 stooges episode! The other side of the coin is that I used to be on the safety team on my previous job and these were just the kind of things that we preached to the guys NOT to do. Seems that some people will never learn until they get hurt.
Old 1/31/07, 11:57 AM
cduphily's Avatar
Originally Posted by mthomas2
Chris,
They seem like good products as well. I have a Werner 22' telescopic ladder(Little Giant knock off). I've been looking for a quality leveling system for it but have had no luck finding something that I could permanently attach without compromising the functionality of the damn ladder.The last link looks like something that may work ... I'll have to check the specs .... Thanks again
Climbing up a ladder today kswift General Inspection Discussion 31 12/27/06 10:48 PM
Ladder Safety from ITA badair General Inspection Discussion 4 8/9/06 6:59 PM
Ladder safety by Rick Bunzel gbeaumont Miscellaneous Discussion for Inspectors 9 3/24/06 5:24 PM
