Old 3/26/10, 9:50 PM
Russell E. Napper Russell E. Napper is offline
Default Lag bolts used as through bolts on a deck
I have inspected a big deck that is about thirty feet high. The contractor has used lag screws as connectors for the joist and beams. These screws go all the way through both metal connector plates but could back out over time. I thought there had to be carriage bolts used with washers and nuts.. any help on this would be appreciated. Take a look at the pictures and let me know. I haven't written the report.
lag-bolts-used-through-bolts-deck-p3260577.jpg   lag-bolts-used-through-bolts-deck-p3260576.jpg
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 3/26/10, 10:08 PM
James E. Braun, CMI's Avatar
Default Re: Lag bolts used as through bolts on a deck
That is funny! I would note the lag screws are not designed for this application and suggest carrier bolts be installed in place of the lag bolts.
Old 3/27/10, 9:00 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Same here, what were they thinking?
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 3/27/10, 2:55 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
LOL, 30 feet high!!! No permits! NO AHJ!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 3/29/10, 11:52 PM
rsovastion's Avatar
rsovastion rsovastion is offline
When you think you have seen it all!
Rick Sovastion
Advanced Home Inspections
1711 Grafton Road
Morgantown, WV. 26508
304-291-8282
Go WVU Mountaineers
Old 3/29/10, 11:58 PM
Nick Gromicko's Avatar
The PICs depict a 6" X 6" post. How did they find a 30' long 6" X 6" ?
In all but the lowest of decks, deck posts should be at least 6"x 6", and be no higher than 12 feet; 14 feet is acceptable if cross-bracing is used.
from www.nachi.org/deck-inspections.htm
Find a Home Inspector
Old 3/31/10, 11:07 PM
I said the deck was 30 ft tall, but it is in three levels. What the pictures show is the first level and the 6x6 are 12'. There are two more levels above this one all with the same lag screws into the Simpson tie plates and all with the same lag screws and only one nut.....the contractor. The builder has since, directed that the screws be replaced with bolts with nuts and washers.
Thanks to everyone for the answers and comments......ya when you think you've seen it all.
Russ Napper
Using the Prescriptive Residential Deck Construction Guide mcyr Exterior Inspections 0 7/21/09 7:10 PM
Check The Deck wdevries Canadian Inspectors 1 7/9/08 2:00 PM
Another deck Collapse rcooke Canadian Inspectors 11 3/30/08 8:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
