Should there be a landing at the top of the exterior basement stair, instead of a step up or step down. Local AHJ says NO problem.
NO PROBLEM?
A step over barrier in front of an open stair. Good grief. I'd write it as a trip hazard no matter what the AHJ said. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Absolutely...good call MIke.
Yup, I'd have that tripping hazard red-flagged too.
Mike Hunt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Tripping hazard, more than 4" opening in stairs, no graspable handrail...
Thanks! Wrote all of that and then some, stairs are not bolted to wall either..
Thanks, again for all your help. |
I'm surprised, and I shouldn't be. That is so obviously a serious trip hazard; I don't know how anyone, even slightly concerned with safety, would so NO PROBLEM!
Harold J. Lowe C.M.I., C.C.I. Eagle-Eye Healthy Home Inspections Sharondale Academy of Home Inspections www.healthyinspections.com harold@cannachi.org haroldjlowe@hotmail.com home-905-576-4337 cell-416-912-0852 CanNachi Director of Education Board Certified Master Inspector Certified Infrared Thermographer Pro-lab Certified Mould Specialist IAC2 Certified Indoor Air-quality Consultant Certified Commercial Inspector Toronto/Durham/Kawarthas Proud InterNachi Member # 06091197 |
I know, I know, not a code inspection but just for interest in my area:
9.8.6.2. Required Landings (1) Except as provided in Sentences (2) to (4) and Sentence 9.9.6.6.(2), a landing shall be provided, (a) at the top and bottom of each flight of interior and exterior stairs, including stairs in garages, (b) at the top and bottom of every ramp with a slope greater than 1 in 50, and (c) where a doorway opens onto a stair or ramp. (2) Where a door at the top of a stair in a dwelling unit swings away from the stair, no landing is required between the doorway and the stair. (3) Except for an entrance from an attached garage, a landing may be omitted at the top of an exterior stair serving a secondary entrance to a single dwelling unit, provided, (a) the stair does not contain more than 3 risers, (b) except as provided in Clause (c), the door is a sliding door or swings away from the stair, and (c) where a storm or screen door is provided, it may swing over the stair if it is equipped with hardware to hold it open. (4) A landing may be omitted at the bottom of an exterior stair or ramp provided there is no obstruction, such as a gate or door, within the lesser of the width of the stair or ramp or, (a) 900 mm for stairs or ramps serving a single dwelling unit, and (b) 1100 mm for stairs or ramps not serving a single dwelling unit. |
Is this a new construction? If not, since Kansas has no state building codes and the locals are usually inspecting new construction only, "no problem" may have actually meant "has nothing to do with me". It's almost impossible to believe that anyone would "okay" such an obvious defect.
It's interesting when a perfectly standard method for constructing outside stairs is met with such outrage. I fail to see any "tripping hazard"...one simply steps up to go down, and then coming the other way, it's the same thing, step up on the top and step down. The purpose of this method is to keep ground water from entering the stairwell. What is the sense of raising the tops of the other walls above grade, if water can just flow down the stairs? I have done dozens of such stairs over the years, and have heard no reports of any problems. It violates no code, and there's nothing wrong with it. Sometimes we reach a little too far.
Jim, the house was in built 2007, in KC metro area.
What about children? When in doubt, write it up. Builder got away with something he should not have. He should be licensed under the new home inspection bill. Shoddy builder, not a shoddy inspection. Trip hazard, lack of graspbable hand rail, no risers, no side railings, all should be written up. And more if seen.
Stairs are over rated
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
| Comment for loft stairs | rbrady | Structural Inspections | 19 | 7/20/08 3:29 AM |
| stairs and railings | cwillick1 | Exterior Inspections | 9 | 6/12/07 9:56 AM |
| Stairs required? | jmichalski | Interior Inspections | 21 | 3/5/06 4:47 PM |
