Old 8/30/09, 8:03 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Leak???
Why doesn't this leak. No stains on the ceiling below this flashing boot.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America)
Old 8/30/09, 8:35 AM
Default Re: Leak???
Maybe it hasn't rained.
Old 8/30/09, 8:38 AM
Wayne B. Wilson's Avatar
Default Re: Leak???
Good one Marcel lol.
Just like the lady asking the fireman why did you Axe my 1000 dollar door it was unlocked.
Old 8/30/09, 8:42 AM
Default Re: Leak???
Good morning Wayne.
Yep, ain't that the truth. They just love to use the axe.
Old 8/30/09, 8:46 AM
Default Re: Leak???
Morning.
Yep I seen it a couple times. And same at car accidents , When i took heavy hydraulics for auto rescue the instructor put us in a wreck and turn the others loose . It was pretty scary watching a Axe coming at a window lol. then he walk over and open the good door . Ah the good old days
Old 8/30/09, 8:50 AM
Default Re: Leak???
It has rained 9 inches this month!! Swinging a axe breaking glass is fun.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/30/09, 8:51 AM
Default Re: Leak???
Only if you are on the swinging end lol
There was no sign of leakage around the pipe inside?
Old 8/30/09, 10:50 AM
Dale Duffy's Avatar
Default Re: Leak???
Damn Buck...are all these screwed up pictures and recent posts from the same "Shack"---
Gas lines, dryer vent, boot flashing, etc-----
If they are, I bet you're still doing the report------
Old 8/30/09, 12:07 PM
Doug Edwards's Avatar
Default Re: Leak???
The simply answer is, that it probably has been leaking. I do not know if you looked at the same vent pipe while inside the attic. Most often if you move the insulation aside you will see exactly where the water has been going. The water runs down the stack pipe and into the interior of the interior wall that encloses the pipe. Those smaller plumbing vents more of than not are concealed inside an interior wall and go to a bathroom. Occasionally, if the water gets onto the ceiling drywall you will find the stains but many times it just runs down the pipe and remains hidden inside the walls behind tubs, showers, etc. Most kitchens have a similar vent stack hidden inside an outside or load bearing wall near the sink. I have some photos of a recent inspection by another inspector that missed this and they called me in to look for why there was a stain that showed up on a bathroom ceiling.
- John Stuart Mill
Old 8/30/09, 12:17 PM
Default Re: Leak???
Doug,
It was a copper pipe. Heavy staining at the sheathing. Nothing on the sheet rock. The insulation just a little damp.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 8/30/09, 12:21 PM
Default Re: Leak???
I see that it is copper now. Didn't look that close. Rarely see copper drains here, mostly either PVC or cast iron. If any water runs past the hole in the double top plate inside the wall you normally won't see it. If you run across this in the future look around for water stains around the baseboards, carpet up against the wall. I got some photos of the lead collars that have been chewed right down to the roof by squirrels that leaked like a sieve but not one ceiling stain.
- John Stuart Mill
Old 10/4/09, 8:52 PM
Salvatore j. Vivona Salvatore j. Vivona is offline
Default Re: Leak???
its a miracle!!!!!!!!!!!!!!!!!!
Underground plumbing leak jhaynes Thermal Imaging, Infrared Cameras & Energy Audits 10 7/31/09 1:34 PM
Leak in bay window with copper roof hmiles Exterior Inspections 19 11/22/08 8:37 AM
Leak in water line outside ... what is ... Bill Featherstone Plumbing Inspections 6 1/12/08 8:17 PM
