Old 11/16/08, 9:15 PM
Hubert A. Miles Hubert A. Miles is offline
Default Leak in bay window with copper roof
I need some help here. I have a friend who asked me to look over this for him. He has a bay window with a copper roof that is leaking. I spoted 2 possible reasons for the problem but wanted to see if I am missing something. The window was installed originally when the house was built 14 years ago. The window has leaked since the house was built, but only in slow steady rains like we get in the fall in our area. It doesn't leak (or at least not that can be seen) when the rains are quick as with fast moving storms.
The 2 things I saw from looking over it was: 1) the flashing over the window does not appear to be installed properly and 2) the brick veneer does not have any weep holes at all anywhere around the house.
The roof originally had copper valleys which were leaking in the attic, but that has been repaired. He thought that may have been the problem. But I saw no evidence that could be the case. The second floor has no signs of water damage in the wall or aroung the fixed window above the bay window. I told him that in order for the roof to be causing the bay window to leak there should be water damage in and around the second floor window as well. It would take a very large quanity of water coming in to the house to cause that much water in the bay window. Thus it was more likely to be a problem with the copper roof installation or the installation of the brick veneer around the window or both.
The builder completely reworked the copper roof in 2001, but the leak persisted and the builder has refused to fix it.
Is there anything I am missing here?
leak-bay-window-copper-roof-gedc0181.jpg   leak-bay-window-copper-roof-gedc0173.jpg   leak-bay-window-copper-roof-gedc0183.jpg   leak-bay-window-copper-roof-gedc0193.jpg   leak-bay-window-copper-roof-gedc0195.jpg
Old 11/16/08, 9:40 PM
Joe Funderburk, CMI's Avatar
Default Re: Leak in bay window with copper roof
Where does the leak show up? At the sill, below it, above the window? Sounds to me like it could be a flashing issue, rather than the roof. If the roof was leaking, that would probably be pretty obvious.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 11/16/08, 9:44 PM
In the interior picture their is staining in the sheetrock above the window and in the wall around the window there are several areas wher the paint is peeling away. The harwood floor has curled at the edges from the water leaking from the bay ceiling onto the floor.
Old 11/16/08, 9:48 PM
OK, I see the stains now. Looks like a roof leak. He's been living with this for 14 years? Why act now?
Theodore Roosevelt
Joe Funderburk, CMI
Old 11/16/08, 10:03 PM
Carl A. Brown's Avatar
Sill of the window above the copper hood!
Old 11/16/08, 10:05 PM
What is on the house for moisture barrier?
Are the windows nail fin windows? What kind of windows are they?
Old 11/16/08, 10:06 PM
He is about to put the house on the market to sell and wants to be able to say the problem has been fixed. He has been actively trying to fix the problem. He has had the ledge of the window avobe the bay reworked, he has had the brick sealed, he had the reroofed the house, and he had the builder rework the bay window. He has had 3 contractors look at it, but no one seems to know what the problem is. He is talking about sueing the builder, and maybe the other contractors don't want the liability issue.
Old 11/16/08, 10:08 PM
Any pictures of the work when it was taken apart?
Old 11/16/08, 10:09 PM
Any backer rod and sealant joint between the upper window and the brick?
Old 11/16/08, 10:14 PM
I don't know about the moisture barrier as I have not seen it and he doesn't know either. The top portion of the flashing is silicone caulked, but I pointed out the gaps to him at the bottom of the flashing and mentioned that the water could be seeping backwards up behind the flashing. I explained to him that the whole purpose for a drip edge on the shingles was to prevent water from backing up into the eaves and that the same principle applies here. If the flashing was not done correctly the water could be seeping back behind the flashing into the roof cavity and into the room. The guy that reroofed the house agreed with me, but the builder says that is impossible.
Old 11/16/08, 10:21 PM
I mentioned that to him as well and again he didn't know. I showed him how the regular windows had the metal header in the brick that supports the brick but also diverts water behind the brick around the window and down the sides of the window and explained to him that there should a method of diverting the moisture that does get behind the brick around the window and down the sides away from the window.
Old 11/16/08, 10:22 PM
Past time for an IR scan.
Old 11/16/08, 10:26 PM
Look at the SILL installation.
Old 11/16/08, 10:40 PM
Thanks for the diagram/guide. I will forward this to him. I feel the problem is probably a little of both the bay and the brick veneer installation. And I don't want to pinpoint any one thing to him because it could be both. Is there anything else I could be missing?
Old 11/16/08, 10:49 PM
Around here the hoods go all the way back to the sheathing and have a return up the wall so the moisture barrier can overlap them.
Most of the time.
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
Moss growing on roof ecox1 Exterior Inspections 45 1/19/06 9:57 PM
