Old 10/7/08, 10:40 PM
Peter W. Bennett Peter W. Bennett is offline
Default Leaking and Defective Anderson Windows under Warranty?
This 13 year old home has several moisture damaged Anderson windows at the bottom of the bottom sashes.
Have you seen this, and have any experience/followup/information with any warranty?
ID:	24486   leaking-and-defective-anderson-windows-under-warranty-115_6845-small-.jpg.JPG
ID:	24488   leaking-and-defective-anderson-windows-under-warranty-115_6877-small-.jpg.JPG
Old 10/8/08, 11:05 AM
Bobby Hamilton's Avatar
Bobby Hamilton Bobby Hamilton is offline
Default Re: Leaking and Defective Anderson Windows under Warranty?
A lot of this I have seen is caused by condensation on the glass, which in Anderson's warranty will state this is a common occurance and will not cover it. But here's a number to Anderson to call for warranty issues 888-888-7020
Bobby Hamilton
Bloodhound Home Inspection Services
Youngstown Home Inspection
Austintown Ohio Home Inspection
Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Old 10/8/08, 12:42 PM
Banned
This should be a winter condition and not this time of the year. Could rainwater be wicking up from the sill through an unpainted lower sash surface or running in between the the side sash and the window jamb?
Old 10/8/08, 12:51 PM
Thanks, but what about the exposed section of window sill that I commonly see?
The windows at the garage have the same condition.
ID:	24516   leaking-and-defective-anderson-windows-under-warranty-115_6820-small-.jpg.JPG
Old 10/8/08, 1:15 PM
Recommend sealing this area. I have had this same type of Anderson window in my own home and the wood under the vinyl completely rotted out underneath it, leaving a nice spongy sill.
Bobby Hamilton
Old 10/8/08, 1:48 PM
Banned
Now I see that these are vinyl clad windows......a bad idea as the seal has to be PERFECT all of the time. If a bit of water gets behind the vinyl, it takes a long time to get dried out and usually rot has begun. I would never buy a vinyl clad window!!!
