The homeowner states the brick stays wet for 3-4 days after a hard rain. They are getting water in the basement dripping down from the sill plate. I checked weep holes seem to be OK no signs of anything on the exterior wall to show leaks. Could the water be soaking in the brick and draining down?
Fix- seal the brick??? any articles out there on this? |
Sounds like a leaking roof behind the bricks.
House is 6 months old, no signs of water on rafters.
Perhaps the bricks are inferior (seconds) and have not been fired correctly. I assume they are clay brick?
Bad grading, maybe? Or possibly a leak in the roof that lets water seep down to the foundation.
All masonary homes should be sealed on a fairly regular basis to help protect from moisture infultration. |
Have you read this recent post? It may be of some use: http://www.nachi.org/forum/showthrea...ghlight=veneer
thanks just copied it and will read it tonight.
grading is good, all sloping away from house 4" of foundation showing.
that is my thought. Would sealing them help?
I don't know of any sealing requirements for brick. Sealing them may work but may cause other problems.
Btw is there sufficent soffit overhang? Also is the foundation concrete or block? |
Overhang is proper, and the foundation is poured concrete.
Any windows in the wall?
Maybe problems with the moisture barriers? http://www.badstucco.com/bricks/bricks.html "I create controversy whether they like it or not" |
Us Zonies have lots of slump block and brick homes and they realy should be sealed to help prevent moisture intrusion and spalling etc. |
No windows where it is leaking, and it is leaking in various places the sameway.
My guess is they could be inferior bricks.
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 7:40 AM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 9:20 AM |
| Brick go boom??? | ccarrington | Exterior Inspections | 11 | 4/24/06 1:25 PM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
