Old 6/27/09, 7:26 AM
John Evans John Evans is offline
Default Ledger Board Flashing
I know deck ledger flashing is a critical component to protect the deck and house structure. However, I almost never find flashing installed during the deck inspection. I do call it out in the report, but the flashing issue will not be corrected in most cases. How often do you find flashing correctly installed and how do you address the missing flashing in the report?
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America)
Old 6/27/09, 9:41 AM
Default Re: Ledger Board Flashing
If I don't see it, I recommend it but I have no control over whether or not they take the advice.
http://www.decks.com/article28.aspx
http://www.homeconstructionimprovement.com/how-to-properly-flash-deck-ledger-board/
Larry Kage, CMI
231 929 3525
Old 6/27/09, 9:52 AM
Carl A. Brown's Avatar
Some installations need different details.
http://www.flash.org/resources/files/HGCC_Fact23.pdf
Old 6/27/09, 9:54 AM
Thank you. I was looking for that PDF file.
Larry Kage, CMI
231 929 3525
Old 6/27/09, 9:57 AM
ldapkus ldapkus is offline
http://www.everflashing.org/
Old 6/28/09, 9:20 PM
John, I find ledger flashing done correctly sometimes; It's correct more often on higher end homes and less often on less expensive homes.
As inspectors serving different areas of North America we often find defects which are accepted locally because all the local contractors are used to doing it the same way- even if it's wrong.
Best practices are the rule to go by. You should always recommend established, correct flashing practices instead of local practices unless there's something obvious. Flashing is not rocket science. You'll have many examples from credible sources to back you up.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 7/1/09, 9:01 PM
William J. Decker's Avatar
I call it out.
Required, by Chicago code, but I have seen many code inspectors not call it out and tell me "it's not really necessary" even though the code requires it.
I call it out, and if someone agrues, I show them the documentation.
If it's not fixed, hey, at least I did my job.
Hope this helps;
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 7/1/09, 9:59 PM
Nice graphics Carl, and here is a picture of a field one.
Old 7/1/09, 11:55 PM
Jeffrey R. Jonas's Avatar
Marcel,
Nice pic... am I correct that there are only screws fastening that ledger board? No bolts?
Old 7/2/09, 5:12 PM
That is correct Jeffery, but they are not ordinary screws.
They are structural screws that are equivalent to lags.
See the data here. http://www.grkfasteners.com/en/RSS_1_2_information.htm
These structural screws are amazing.
Old 7/2/09, 6:51 PM
For those that haven't seen these, here is a good video:
http://www.grkfasteners.com/en/RSS_0...tion_video.htm
Larry Kage, CMI
231 929 3525
Old 7/2/09, 9:00 PM
Thanks Larry for the addemdum to the topic. I should have posted it, but assummed everyone would see it.
One has to use those to see how effective they are.
Here is a better photo of the screw being installed.
Hope this helps.
Old 7/2/09, 9:25 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
http://www.nachi.org/gallery/exterio...lashing-3d.jpg
Find a Home Inspector
Old 7/2/09, 9:33 PM
Nice graphic Nick.
If you look at the first pic of my post, the membrane flashing under the ledger board, is kept loose until the siding installation underneath is intalled.
Once the siding is up to the ledger on the underside, the course of siding before last is tucked under the membrane flashing that was installed behind the ledger. Then the last course of clapboard siding is installed.
So if water intrusion occurrs behind the ledger, it flows out onto the clapboard face of the subsequent layers of siding.
Hope this make sense, remember, I am French.
Old 7/2/09, 11:32 PM
Marcel / Larry,
Thanks for the links. I hadn't seen these yet. Now I will recognize them whenever I do.
Cool beans!!!
Jeff
Ledger board question pcoulter Exterior Inspections 2 4/18/09 9:09 PM
Kansas Board Approves NAHI and ASHI Tests - Denies NACHI Test jbushart Legislation, Licensing & Legal Issues for Inspectors 29 2/22/09 6:15 PM
Free mailing labels and postage for anyone wanting to write Kansas legislators. gromicko Legislation, Licensing & Legal Issues for Inspectors 739 1/22/09 11:18 PM
Yippee!!! Kansas AG says association membership requirment unconstitutional! gromicko Legislation, Licensing & Legal Issues for Inspectors 41 11/30/08 1:34 PM
Read the message board rules: gromicko Miscellaneous Discussion for Inspectors 39 3/19/08 3:24 PM
