Is this acceptable method using a ledger strip.
It seems to me the nails could easily pull away and joist hangers would be more secure. |
| Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America) |
My first thought is that ledger should be continuous.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
That is a good point!! Thanks. Doing inspection tomorrow. Did the exterior yesterday when I set up radon test. Just thinking of some good report verbaige. |
l would bet there is NO flashing behind the ledger board. Let us know.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
It seems it is rare to find a flashing these days.
Recommendation I use for ledger strips ..... Ledger strips can be used in lieu of hangers or wall bearing. Ledger strips apart under each joist location.are to be 2 x 2 minimum and anchored with 3 - #16 nails * spaced 2 3 Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
The ledger is fine........
And just to let you know..... a typical 10d - 16d nail has 200 lbs of holding power....how man nails and ledger strips are needed to support each joist.......... it would have been nice to have the 2x2 ledger be continuous however it is not required. There should be flashing behind the band joist and the band should be bolted with 5/8" galvanized bolts. (nails should be galvanized as well). |
One of the things I see more often are lack of bracing (deck over 48")........I think Nachi has a section on decks somewhere on the site. Also look for screws being used to fasten joist hangers....these do not have the same shear strength approved nails. |
National statdards call for flashiing OVER, not behind, the ledger board.
Hops this helps. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
I don't have a problem with it not being continuous. However, there are not enough nails. As someone has already said, there should be 3 nails beneath each joist. That one joist sitting on the edge of the ledge...I don't see how you could nail it substantially with 3 nails. I don't think the joist should sit on the edge of the ledger.
The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life. Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The ledger strip should be continuous as a standard practice to distrubute the load evenly among the fasteners.
It seems odd that I don't see any toenailes in the framing members to the ledger and no fasterners visible in the ledger itself. Floor joists should have a minimum of 1½" of bearing at each end. When joists butt into the side of a beam, a ledger strip can be nailed onto the beam to provide the necessary bearing surface. Ledger strips are typically 2" X 2" and are fastened to the beam with two 3Ό" nails at each joist. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Not back in those years Joe.
| Ledger Board Flashing | jevans | Exterior Inspections | 15 | 7/2/09 10:42 PM |
| Ledger board question | pcoulter | Exterior Inspections | 2 | 4/18/09 8:09 PM |
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
