Old 6/27/10, 11:46 AM
Peter W. Bennett Peter W. Bennett is offline
Default Lintel Sag Formula
new construction (2 years) old
The lintel has a sag.
What's the formula for determining the sag is acceptable/unacceptable?
pb
Need a home inspection in Idaho? Check out InterNACHI's listing of Idaho certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/27/10, 12:23 PM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Re: Lintel Sag Formula
a divided by b and c equals the acceptable lintel sag.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 6/27/10, 12:28 PM
please clarify a, b.
Old 6/27/10, 1:25 PM
pb
Was there additional information, like cracked brick/mortar, etc., visible?
Lintel design information may be found in Technical Notes
17B http://www.gobrick.com/html/frmset_thnt.htm
and 31B http://www.gobrick.com/html/frmset_thnt.htm
If this information is more than you feel confident understanding or relaying, you may consider reporting only what you see.
Larry Kage, CMI
231 929 3525
Old 6/27/10, 2:11 PM
gap between mortar joint and lintel was approximately 3/16".
Old 6/27/10, 5:45 PM
James E. Braun, CMI's Avatar
Something is going on there. It should not sag that much on that new of home. It will only get worse. I would call it out, refer it to a structural engineer and move one.
lintel support krentz General Inspection Discussion 3 7/28/09 12:41 AM
Steel Lintel hmcbride Exterior Inspections 13 9/28/08 3:37 PM
And yet another new CMI formula proposal (July, 2006). This one should satisfy all. gromicko Miscellaneous Discussion for Inspectors 258 7/7/06 9:32 PM
