Old 10/23/06, 3:37 PM
mthomas2 mthomas2 is offline
Default Lintel sealant question
1) Should this be sealed at the side?
2) Since there is no "manufactuer's recommendation" as to sealant type, how are people here phrasing their recomendations for the material used at such junctions?
Old 10/23/06, 5:27 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Default Re: Lintel sealant question
Michael
I have never seen this type of lintel used for a window or door.Having said that any type of sealent that remains soft year round would be good as a remedial fix.
Proper lintel should be an L shape and vertical should be in behind bricks and horizontal under bricks supporting them.Sorry I don't have a picture.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 10/23/06, 5:34 PM
Mario, thanks - I've never seen it done this way either, and IMO its certainly not "right", and water standing on the upper surfaces of those lintels is always going to be a problem. But that said, what might I suggest (other than regular inspection, scraping and painting) to deal with it - it's a bit late to improve the design or flashing details now.
It seems to me that you want to limit water contact with the lintel ends and water entry into the wall above the window via openings at the lintel ends, but at the same time you don't want to to trap water behind bricks above the lintel or at its lower corners where it rests on the brick below. Here's what's happening currently:
Old 10/23/06, 6:15 PM
Michael
Just use a good exterior silicone sealent.MONO is a good product.
Tel.# 416-722-6132
Old 10/23/06, 7:16 PM
I have to agree with Mario;
I have never seen this type of brick lintel before.
A c-channel was not designed for a lintel and this installation is allowing water intrusion behind the lintel, because it is protruding the face brick and it will find it's way in the cavity and now wonder where the head flashing may be or does it exist at all.
Completly wrong all around. I would write this one hard.
Marcel
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 2:04 PM
Plumbing vent Routing Question kweiss Plumbing Inspections 7 11/1/06 10:57 PM
Rule of Thumb A/C sizing question from Practice Exam gliebig Inspecting HVAC Systems 9 5/25/06 2:38 AM
Answer to a common question about GFCI's jtedesco1 Electrical Inspections 4 1/12/06 10:29 PM
