At what point/height is guy-support required for a masonry chimney?
How high/wide can an unsupported masonry chimney be? Are measurements taken from the ridge or eave side? Any charts, codes, or other info would help. This picture was thrown in as a joke. Thanks in advance.
I don't see anything wrong.
It hasn't, like, fallen down or anything, has it? "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
If the roof ridge is more than 3 feet below it, that huge missing section could be considered an alternative for a rain cap...
lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't think there is a requirement for support. I will check my code book. If I remember correctly if the chimney is that high it is supposed to come up through the roof wide and be corbelled down to a smaller size.
Larry |
I just checked and the code says bracing is required if the height is greater than 11' above the masonry part of the wall. code ref 9.21.4.5
Larry |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 4:05 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Floating Chimney Syndrome | mcyr | General Inspection Discussion | 8 | 7/25/07 12:49 AM |
| Is this a chimney support or what!!!!! | cbottger | Structural Inspections | 2 | 4/5/07 11:23 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 6:08 PM |
