Old 10/20/06, 7:49 AM
John Onofrey's Avatar
John Onofrey John Onofrey is offline
Default Master bedroom has no window...
the only emergency escape opening is in the master bathroom water closet. I an interested in opinions regarding this because it does not seem to be clear in section R310 of the IRC.
Does the emergency escape opening have to be in the sleeping room itself or does the adjoining bathromm WC window qualify?
A "study" is listed as a bedroom by the seller. There are two door openings into the room but not directly to the exterior. Does this room qualify as a sleeping room?
Appreciate your input.
John Onofrey Licensed Professional Inspector
Houston Home Inspection
Houston Home Inspector
www.texasinspectors.net
John Onofrey
President, Grail Media, LLC
"Effortless Email Marketing"
www.homehintsenews.com
2007 INACHI Inventions and Innovations Award Winner
Free! Inspector Email Marketing trial click here
Old 10/20/06, 8:34 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is online now
Default Re: Master bedroom has no window...
Does it have a closet?
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 10/20/06, 8:42 AM
Study and master both have closets.
John Onofrey
Old 10/20/06, 11:25 AM
bsumpter bsumpter is offline
In my area at least, a bedroom does not have to have a closet. Heat, power and emergency egress.
Brian R. Sumpter
First Call Inspections
Proudly serving most Bay Area Counties
www.firstcallinspections.com
Jeffrey R. Pope's Avatar
Originally Posted by jonofrey
Does the emergency escape opening have to be in the sleeping room itself?
Absolutely, 100% yes.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/20/06, 11:26 AM
gkoehl's Avatar
gkoehl gkoehl is offline
I thought that all habital rooms has to have natural light @ a min 8% of the sq ft of the room
George Koehl
Collinsville, TX
TREC# 9435
NACHI ID: 06092190
InTex Inspections
Old 10/20/06, 11:28 AM
If it does not have a window, it's a storage room/closet, not a habitable space.
I'm headed out the door this morning. I can elaborate later. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 10/20/06, 2:13 PM
Bedroom Definition
Q. Do you have a definition of a bedroom in the Dwelling Code? I'm currently building a house which has a specific room dedicated as a exercise/weight room. The inspector is calling it a bedroom and requiring me to install smoke alarms and an egress window. This room is not a bedroom and I feel it's wrong for the inspector to insist on these requirements. Doesn't a bedroom have to have a closet or something like that? This room doesn't have a closet and has a lot of special wiring done to accommodate the exercise equipment, which should make it obvious we plan on using it for a exercise/weight room.
A. The Dwelling Code does not define bedroom, so we need to go to the dictionary for a definition. The definition in the dictionary is; "bed-room: a room furnished with a bed and intended primarily for sleeping."
It is not uncommon for someone to submit a set of plans which has an extra room designated as a den, office, weight room, library, etc. The primary use in these rooms is not intended for sleeping. However some contractors and/or homeowners may designate a room as a den or office to circumvent the local SDC's (System Development Charges) or septic tank requirements or sometimes the original owner may use this room as it was designated on the plans, but the next owner has a larger family or their mother-law living with them and they end up using the "den" as a bedroom. The cost of smoke detection and appropriate egress windows is small compare to the cost of a human life, therefore it may be advantageous for the local jurisdiction to require these safety provisions, but the homeowner/contractor should be given the benefit of the doubt for the purpose of the SDC's. It is inappropriate for a jurisdiction to tell a homeowner/contractor how each room of their home will be used or classified. There are many times when it is obvious the room in question is not a bedroom, i.e. no closets, a door leading to the outside to be used as a office entrance, wall of shelving for library use, special provisions for exercise equipment, etc. These rooms need to be treated as designate on the plans, not based on speculated future use. If, however, this room had a closet in it and the only distinguishing difference is that it's called a "den" on the plan, then the requirements for smoke detectors and egress windows would be appropriate.
I found this in the Oregon Salem Newsletter a whole long time ago. I think it has to do with Oregon interpretation.
Old 10/20/06, 3:35 PM
Robin N. Byrd Robin N. Byrd is offline
In my area a bedroom has to have a closet space WITH doors of some kind to be "listed" as a bedroom.
R. Nicole Byrd
Byrd-House Inspections
Belpre, OH 45714
NACHI #06090597
Old 10/20/06, 4:14 PM
Window is required as Jeff pointed out.
NFPA Life Safety Code Chapter 24. I believe a little common sense would automatically mandate that there is an other means of egress. JMO
Marcel
Old 10/20/06, 5:05 PM
Natural light supplied by skylights.
John Onofrey
Marcel
John Onofrey
Old 10/20/06, 5:06 PM
Correct.
John Onofrey
Old 10/20/06, 5:08 PM
I agree. This three bedroom townhome just got downgraded (in my mind) to a one bedroom.
John Onofrey
Old 10/20/06, 5:09 PM
rwand1 rwand1 is offline
Is this a new or old house? If newer housing yes it would require a window, but if the house predates the code then it does not have to be retrofitted in my opinion. Many older homes did not have closets they had armoirs (sp?) (free standing closet)
CMI, MBI whatever. tallen General Inspection Discussion 7 7/11/07 9:25 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 4 4/23/07 8:31 AM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 11:48 AM
