Hello y’all.
I am reaching out for some of that experienced NACHI assistance on a situation I encountered and have never heard of nor seen anything like it. I inspected this home and the vinyl siding appears to have melted in several locations - by the A/C auto shut-offs, on the chimney, adjacent to the A/C compressor. None of those should have caused this..........or could it? I am including several pictures which should be legible. If not please let me know so I can figure out what went wrong. Thanks in advance for any and all input. Have a Groovy Day. randy c |
| Find an InterNACHI certified West Virginia Home Inspector (and anywhere else in North America) |
If this is near the chimney or fireplace, I would take a real good look at the flue and the firebox.
Where in relation to the electrical panel is the fireplace?? ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
It's more likely from the sunlight being reflected off those window behind the AC unit. Notice how there is a small area under the electrical box that is not blistered? That's a shadow area created by the box. The upper level part is probably from the upper windows reflection. I've seen this a couple of times, the strangest was from a neighbors house. But like Shawn said, since this is on the fireplace, you should definately recommend a Level II inspection to be sure that isn't the source. (My answer isn't that big a deal, a leaky fireplace will kill.)
I was thinking the same thing as Mark. Reflection. But Shawns' answer does possibly make sense.
Relections off the windows and exterior walls.
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
I also wonder about those vents in picture two.
one appears to be a dryer vent but is right next to the compressor . Also laying on the ground is PVC piping that appears dismantled. In the background I also see what looks like schedule 40 . Both of the above seem to be in the wrinkled area and the liquid tight looks as if it is rusting prematurly. |
Tough call on that one Bob, but did find this that looks like the pictures above and caused by the dryer vent.
http://www.inspect-ny.com/exterior/vinylsid.htm LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Now I really wonder what the other vent is for? Without being there we can only guess. |
I've seen that 3 times in 4 years. Thermal damage caused by the sun's reflection is what I always assume. Recommend an evaluation by a siding specialist.
What's puzzeling, is that I have the same siding on my house with the vinyl dryervent adaptor that comes as an accessory and no way did it damage my siding from using the dryer.
I've seen similar damage from barbeque grills, but this photo is not from that either. That is a good one for sure to figure out. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
That was very interesting Joe, never seen or heard of this before, but did see a few comments below that were from Maine. Got to be a defective product to distort like that from mere reflections. The back side of my house is directly in the sun all afternoon in the summer and shows no sign of distortion. This could be an issue of cheap vinyl siding also. I bet it was nowhere close to a 55 mil product. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
More discussion on this phenonmena on Active Rain.
http://activerain.com/blogsview/1385...-You-Ever-See:) LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Interesting Article here from VSI on the subject.
Worth a read. http://www.foundrysiding.com/PDF/tec...on_foundry.pdf LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Composite Concrete siding Issues I need Help | rkie | Exterior Inspections | 13 | 5/1/08 7:27 PM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 4:32 PM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 9:46 PM |
