jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
I know that the termination of a chimney should be 2' above any part of a building within 10 feet.
But I'm looking for what the proper clearances (above and beside) are for trees from the termination of a metal chimney. I know this is too close (currently about 5 feet to the side and above) but am not sure how far away the tree should actually be. Any help would be appreciated. |
It is not the Chimney that is the Hazard. It is the Tree.
http://www.na.fs.fed.us/spfo/pubs/ho...haz/ht_haz.htm Recommend pruning and/or removal of the Hazardous Tree. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I'm not sure you would be able to find anything that shows an answer to your question.
However, in this case, I would recommend that they consider removing the tree in its entirety, as it is encroaching on several systems of the home that may become damaged, or otherwise function "improperly." Things that come to mind are the chimney, roof/eaves, service drop (seen in the picture) and possibly the foundation. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Jeff,
A Tree with Limbs within striking distance of a structure is Hazardous. A recommendation of Pruning and/or Removal is warranted. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
Potential Hazards.
Too close to the Structure. Compromising the Foundation (There are many 100 year old rubble foundations in this area) Dead / Decaying limbs. Overgrowth and visible lack of maintenance/pruning. Etc.... ......... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
| Light Bulbs- All Ya Wanna Know | pabernathy | Electrical Inspections | 9 | 4/18/07 7:22 PM |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Miscellaneous Discussion for Inspectors | 8 | 1/25/07 5:22 PM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 5:08 PM |
| metal chimney height | jclark1 | Exterior Inspections | 7 | 7/6/06 5:37 PM |
