Old 5/13/08, 8:05 PM
ckirby2 ckirby2 is offline
Default Metal Roof Decking Question
Haven't done a lot of metal roofs and so hoped someone could answer a couple questions for me.
Did an inspection today on a house built in 2006 that had a metal roof. While in the attic, I noticed that there was no plywood or OSB sheathing/decking between the rafters and the metal sheets. Is this allowable/correct? All the metal roofs I have seen have had some sort of decking, but then again, most of those roofs were installed over an already existing roof.
Also, there was a vent pipe that didn't go through the roof. I assume that is incorrect for a metal roof as it is for a shingle roof.
Any help would be appreciated.
metal-roof-decking-question-roof-attic-view.jpg   metal-roof-decking-question-pipe.jpg
Old 5/13/08, 9:00 PM
James F. McKee's Avatar
Default Re: Metal Roof Decking Question
the purlins support the metal roof without sheating Clint, but You are right about the vent....that is just plain wrong...IMO....jim
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 5/13/08, 10:05 PM
Thanks, Jim.
Is that a typical metal roof installation for a new roof, i.e., with no decking/sheathing? If so, is it done that way because it is cheaper and/or faster? Just curious...
Old 5/13/08, 10:12 PM
Yes to all of the above as far as I know....I'm sure no expert , but this is the way i see them on new construction....jim
Jim Mckee
Amherst, Ohio
Old 5/14/08, 7:06 AM
This link may help a little.
http://www.bestbuymetals.com/pdf/tuf...tion-guide.pdf
Marcel
Old 5/14/08, 8:45 AM
Barry Adair's Avatar
In your photo there appears to be a lot of eave daylight. That usually is an indication that the profile vent/stop material was not installed, is displaced or has failed.
Vermin, insects and birds can become problematic when this feature is omitted. This is not necessarily a defect, more of a nuisance issue and advising the client along with a note in the report...avoids call-backs
HTH
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 5/14/08, 7:16 PM
Thanks fellas. That was a big help!
Old 5/17/08, 10:34 AM
I see a lot of metal roofs and have never seen one installed without roof sheathing. According to this link it depends on the product. Most metal roofing is not very thick. Did you walk the roof? I would definitely call out the lack of a membrane.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 5/17/08, 2:18 PM
jkogel jkogel is offline
Could this house be a converted shed?
Up here in wet country, on a closed-in dwelling with heat, some kind of sheathing would be recommended, and even 15 lb felt is better than nothing.
But just tin on strapping is pretty common for sheds and workshops with lots on open air under them. Makes it easier to find the leaks after a windstorm!
John Kogel
www.allsafehome.ca
question??? Metal roof sweating mjohnson6 Exterior Inspections 6 2/16/08 12:45 AM
Tile Roof Question mhawley Structural Inspections 2 9/5/07 9:59 PM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Metal roof inspection Joe Griffin General Inspection Discussion 2 5/13/07 8:44 PM
