Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
LinkBack Thread Tools Display Modes
Old 9/28/08, 3:40 PM
Erich Kelter's Avatar
Erich Kelter Erich Kelter is offline
Erich Kelter is often very helpful Erich Kelter is often very helpful
Default Metal Roof Installation
Checked out a metal roof for a client today. They had problems with the contractor and have some leaks. A couple of questions popped up that I didn't have immediate answers for...
Should I be able to see light thru the holes under the ridge capping in the pics below? Some areas are open and others aren't..
Also the installer shoved pieces of foam under the capping at each bottom corner of the roof? Seems a little suspect to me....??
Thoughts?
http://i301.photobucket.com/albums/n...ttaVR6/008.jpg
Old 9/28/08, 3:56 PM
Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute Marcel R. Cyr has a reputation beyond repute
Default Re: Metal Roof Installation
Thoughts?
Hi. Erich; Never seen this type of roof before, but first thing in my mind would be, did the light come from the attic indicating roof venting?
Did or were you able to find out the Manufacturer of the Product used.?
If so, would that help in reviewing the Manufactures Installation Procedures.?
That is all I can provide. Sorry.
Marcel
Cyr Home Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards/inachiawards551.html
Commercial Builder
Ouellet Associaties Inc.
Old 9/28/08, 6:52 PM
Jerry B. Yost Jerry B. Yost is offline
Jerry B. Yost has had a little positive feedback
I agree about finding the manufacturer and getting the information on installation directly from them. Hopefully the light is ventilation, and the foam is approved. Good Luck.
Jerry Yost
Golden Rule Property Inspections
http://www.MyTexasInspector.com
HomeInspectorOne@hotmail.com
TREC #09097
NACHI06060660
Certified Infrared Thermographer #05080018
Certified Pool & Spa Inspector
Old 9/28/08, 8:33 PM
The homeowner did not have the mfg. info readily available but he did mention he checked their installation guidelines and could not find any info about the item in question. The light is not from attic ventilation, its actually a gap you can see right through to the other side of the cap. My main concern was the possibility of a wind driven rain or snow blowing into the gaps causing leakage, which at the time of inspection there was no evidence of...There was a bunch of other details that the installer did poorly, open screw holes, half installed screws, poor flashing details, damaged sections of tile, damaged finish causing rust to start, and the list goes on....
Old 9/28/08, 8:46 PM
Barry Adair's Avatar
Barry Adair .
MRW carries the same or similar.
From your description...further evaluation by a qualified roofer is all I can say
badair
http://www.adairinspection.com
972-487-5634
Dallas & Garland, TX 75228 & 75042
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
04080595
Voted, by a slim margin, InterNACHI U.S. Member of the Year 2008
life is the random lottery of events followed by numerous narrow escapes...accept the good
http://www.gunlaws.com/images/unitys.gif
Old 9/28/08, 8:52 PM
Agreed. This is what I advised my client to do. Thanks for the website Barry.
Old 9/28/08, 10:29 PM
William E. Siegel William E. Siegel is offline
William E. Siegel is often very helpful William E. Siegel is often very helpful
Forget another roofer. Sounds like you need the manufacturer to send a rep out to inspect the install.
Bill Siegel
Florida Home Inspection Team Inc.
Old 9/29/08, 1:13 AM
Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information Kenton H. Shepard, CMI is very trusted source of information
If it looks like rain can blow in... it probably can.
Qualified specialist, either roofing contractor or mfg's rep, whichever is easier but qualified.
Kenton Shepard, NACHI member # 04082383
Peak to Prairie Inspection Service
Inspection of Conventional,
Log, Strawbale and
Historic Homes
(303) 258-8289
Old 9/29/08, 2:24 PM
Ah yes, forgot to mention that as well, client did contact the mfg. but didn't ask a rep to come out. I suggested he give them a call back and do this.
Display Modes
Metal Roof Decking Question ckirby2 Exterior 8 5/17/08 3:18 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior 6 10/13/07 9:10 AM
Ice Gaurd membrane dmacy Exterior 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior 9 2/15/07 2:19 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
