mnicholet is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have looked at a couple of metal roof installs in my area with penetrations flashed in this manner. I called out the last inspection, the roof contractor told the client it is installed correctly. Anyways, can you please look at these pictures and let me know what you think. I am not sure how the water that enters into the penetration is going to shed back out to the exterior side of the roof covering. Your thoughts and recommendations including how to write this up is much appreciated. Thanks.
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Try and find manufacture recommendations for roof penetrations. it does not look right to me, water can get under metal
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
It looks suspect. See below.
See page 3. http://www.tamko.com/Portals/0/docum...t%206-8-09.pdf It's possible that the the lower shingle is covering the bottom of a correctly installed vent flashing but I also question if the boot is properly sealed against the vent pipe and see a wrinkle in the boot near the top. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father Last edited by mlarson; 1/23/10 at 2:52 PM.. |
More info: http://www.roofingcontractor.com/Art...100000f932a8c0____
Mark, I am not familiar with that product, but agree with you that it does not look right.
I would try to find out the Manufacture and do some research to back up you stance with the roofer. Even better, get the roofer to prove to you by detail that it is correct. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
installed incorrectly write it up!
picture 2 shows that water can get under metal roofing. not that it maters but is this a re-roof over existing asphalt shingles?
Mark,
We're you able to access the area from the attic to see if there was any evidence of leaking? Putting a moisture meter on the suspect area could goca long way solving the question, in addition to looking at the mfg recommendations. Jeff Tatlock www.beachsideinspection.com |
May not be allowed but then we are not code!
Metal roofing over existing asphalt shingles is not considered 2-layers by most code officials as the 2nd layer is metal and doesn't add any extra weight.... and so is often permitted, even in jurisdictions where only one layer is permitted. Complete tear-off not required. Old asphalt layer acts as metal roof's underlayment.
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 1/24/10 at 2:39 AM.. |
There was no asphalt shingle(s) under this metal roof covering and as far as I could tell it was cedar shake/shingle prior to this installation. The penetrations in the roof covering did not appear to be leaking from the attic inspection. From the picture view it just does not make alot of sense to me how the water is not intruding. I was hoping someone could explain it to me. Perhaps there is/was non accessible sealant that is preventing water leakage but we all know what happens to sealant over time...
Yeah that sure looks like water would go between the metal and the rubber boot.
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 3:59 PM |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 1:52 PM |
| Metal Roof Decking Question | ckirby2 | Exterior Inspections | 8 | 5/17/08 3:18 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
