Old 10/13/09, 4:06 PM
John Evans John Evans is offline
Default Metalbestos flue pipe
Inspection this morning. A wood stove located basement is connected to Selkirk stainless steel metalbestos flue pipe. The flue penetrates the block foundation wall BELOW GRADE and runs vertically about 2 feet before emerging from the ground. It then runs vertically at the side of the home with normal above roof termination. Does anyone here know of flue standards that apply to this unusual installation? Moisture, corrosion, leakage, etc are some of the potential issues.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Find an InterNACHI certified Iowa Home Inspector (and anywhere else in North America)
Old 10/13/09, 6:30 PM
Wayne B. Wilson's Avatar
Default Re: Metalbestos flue pipe
Well to start with it is suposed have 2 inches from combustibles MULCH is wood . I would call a supplier and ask about being buried It is probably not designed or made for that. Just when you think you seen it all , Then poof another one pops up .
Old 10/13/09, 9:08 PM
Remember to contact your local code office before proceeding with your installation. Some counties have abnormal requirements for clearances, and even types required for your appliance.
Some clearances that may differ from county to county are:
Clearance to windows/doors/air inlets
Clearance from the ground
Clearance from a sidewalk/path
Minimum roof termination distance (How far the pipe is above)
Old 10/13/09, 9:13 PM
What i am wondering if there is covering flue pipe being buried Marcel, No way of checking when it rust out. Then there would be a problem with carbon monoxide .
This should interesting in the different views .
Old 10/13/09, 9:24 PM
Wayne, I would have a hard time to believe that this installation is right.
Someone would have to work hard to convince me also.
It is just plain wrong, and don't care if it is made of stainless steel, but the joints are not waterproof, they are water resistant to proper above ground installation.
Old 10/13/09, 9:30 PM
Yes i was thinking that myself. I never seen it before and i have seen some strange things around here.
Old 10/13/09, 9:37 PM
That is an odd one.
I'd just call it too close to combustibles, refer it out, and be on my way but I am curious what possessed them to install it like that.
Larry Kage, CMI
231 929 3525
Old 10/13/09, 9:50 PM
I think I found it here;
http://rds.yahoo.com/_ylt=A0geu_YTH9...ia_install.pdf
12" ground clearance required.
Old 10/13/09, 9:58 PM
Thanks Marcel
Just added that to the old collection.
Old 10/13/09, 10:04 PM
Your more than welcome my friend. Just hope it helps others.
Old 10/13/09, 10:07 PM
It may be different for a wood burner than the corn/pellet stove info posted but it still isn't right the way it is buried.
Larry Kage, CMI
231 929 3525
Old 10/14/09, 1:23 AM
Dale Duffy's Avatar
Attachment 32592
Attachment 32593
Attachment 32594
Hi John,
I have never seen a Wood Stove here, but that is certainly an odd configuration---
Old 10/14/09, 6:11 AM
Marcel,
Thanks for the information. I had to release the report before your post, but I did refer the flue installation to a qualified stove or chimney installation company. I know there is a good chance that corrosion and/or leakage has occurred in the buried section. The original installation was at least 11 years ago according to the owner. Must have been an amateur installation.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 36 10/27/10 11:21 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 2:23 AM
Is this allowed? relliott Plumbing Inspections 4 7/15/09 7:40 PM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 7:39 PM
What's Inside A Chimney mcyr Inspecting HVAC Systems 14 9/17/08 7:11 PM
