I saw this today for the first time. What will they think of next??
I have been studing NovaBrik for a few years now. There are also a few building in my area that have been done in it and look very good. The thing I like best about mortarless is that you don't see any pesky cracks due to slight movement like you do with traditional brick.
I am however concerned with the amount of required attachment vs weight however I am not an engineer. |
Even with the overlap shouldn't there still be a drainage plane behind it?
Nova Brick Installation
Shows house wrap and taped joints behind brick face in wall preparation section. PDF Format Last edited by mlarson; 7/20/07 at 5:41 PM.. |
The key word here is UNSKILLED LABOR can be taught to build.
THE TWO BLOCK ADVANTAGE With only two blocks, as compared to as many as seven in other systems, building is easier than ever. The two components are the combination stretcher-corner-end-block and the half block. Labor cost is reduced as block laying is up to 10 times faster while the possibility for placement errors is virtually eliminated.Unskilled workers can be taught to build with Haener Block on the job site with a minimum amount of training.
Semi-skilled, unskilled or do-it-yourself labor can lay Haener Blocks Pretty cool isn't it? Thanks for the link. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks for your link Marcel. I have'nt seen the Haener product yet.
Marcel,
I remember when you couldn't upload a photo to this message board. Look at you now. |
I guess we are never to old to learn. ha. ha. Thank you all for the Contribution to this BB. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
The NovaBrik (and there are some others) are a siding. They provide no structural support. The Haener Block is a structural block for poured concrete (like an ICF without the I
I would like to see a concrete form that has an insulated form on only one side and something else like concrete on the other. Kind like half ICF and half Haener block. If anyone knows of such a product please let me know. |
And..... should the firring strips be PT? |
Paul;
Your to fussy. ha. ha. See what I can find. Rule of thumb, if someone can think of something, chances are it is out there for you to find or will benifet from the makings of a new Product. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
One other thing to point out is carpenter ants will go right through the foam and nest in it or the wood, so the firring strips might also be treated with borate, but this would not stop them from getting into the foam.
Very bad situation. |
| Why do brick spall? | mbryan | Exterior Inspections | 68 | 9/1/11 10:10 PM |
| Backfill on brick veneer | bpaull | Exterior Inspections | 4 | 7/12/07 7:40 AM |
| Brick-Veneer Inspection Guide | jbowman | Exterior Inspections | 12 | 1/8/07 9:20 AM |
| Brick go boom??? | ccarrington | Exterior Inspections | 11 | 4/24/06 1:25 PM |
| Massachusetts Clay Brick Education | ajalowsky | Miscellaneous Discussion for Inspectors | 2 | 2/22/06 6:34 PM |
