How do any of you address moss on the roof, verbage and alike.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
I note that there is moss buildup on the roof shingles and recommend removal.
When the client is with me I say a stiff broom works good to get it off because moss holds moisture and can rot the shingles. If you scuff off some moss, you'll see the damage started. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Recommend when reroofing add zink strip to top layer of shingles to help control moss. Cookie Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. Last edited by rcooke; 9/9/07 at 6:52 PM.. |
Larry
What would cause this, maybe moisture under shingles? "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
Roy's zinc strip is good and they have been making shingles that resist moss growth for a while too.
dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Gary,
Many times the moss grows because of shade. How far away are trees or other items. If direct sun is able to hit the roof material, the moss will not grow. Do they need some trees trimmed back??? |
David
Yes they do need trees trimmed. "I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison www.newbeginningshomeinspection.com |
| How much does moss growth affect roof life span? | fbartlo | Exterior Inspections | 9 | 8/1/07 5:31 AM |
| NACHI holding N. American Convention at Toronto Congress Centre in 2007. | gromicko | Canadian Inspectors | 178 | 11/22/06 2:55 PM |
| Moss growing on roof | ecox1 | Exterior Inspections | 45 | 1/19/06 9:57 PM |
