Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 1/12/06, 12:47 PM
ecox1's Avatar
ecox1 ecox1 is offline
Send a message via Yahoo to ecox1
Default Moss growing on roof
I love my job
Old 1/12/06, 1:00 PM
twheeler
Guest
Posts: n/a
Default Re: Moss growing on roof
So, whats your question?
Old 1/12/06, 2:26 PM
ecox1's Avatar
No questions just sharing my views
Old 1/12/06, 5:42 PM
twheeler
Guest
Posts: n/a
Cool!!!
And I love my Job as well!!
Old 1/12/06, 7:13 PM
rcooke rcooke is offline
Banned for Violating COE
Please Note: rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Yep moss on Roof .
Do you know what caused it
Do you know how to avoid it in the future .
Do you know what you shpuld do about it
Do you know what you should not do about it.
Roy sr. ..... I know
Old 1/12/06, 8:49 PM
Carmine Fuoco's Avatar
Carmine Fuoco Carmine Fuoco is offline
I hate to upstage you Earl. I also love my job.
Old 1/12/06, 8:52 PM
Another
Old 1/12/06, 9:00 PM
Moss can and does shorten the life span of asphalt as well as other shingles.
Old 1/13/06, 12:28 AM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
can i play too?
Old 1/13/06, 12:40 AM
Dale Duffy's Avatar
Jay, nice tight-rope......also.
Old 1/13/06, 2:02 PM
Kevin P. Williams's Avatar
Kevin P. Williams Kevin P. Williams is offline
How about this ??
Old 1/13/06, 2:53 PM
NWJon NWJon is offline
Please Note: NWJon is a non-member guest and is in no way affiliated with InterNACHI or its members.
My wife, "a florist", loves moss... can you email me some? lol
Kevin... what is MAB?
Old 1/13/06, 3:06 PM
jmichalski's Avatar
jmichalski jmichalski is offline
Please Note: jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin has a winner!!
I lifted this section about moss and algae growth from somewhere, but I like it alot....
"Significant moss growth was observed on the roof, usually a result of lack of sunlight, high moisture. This natural growth can significantly decrease the life expectancy of this area of roofing and is recommended to be cleaned, and the overhanging branches trimmed back. Some recommendations for cleaning the shingle roofing are included below:
Moss is quite easy to remove. Use a standard bristle scrub brush on a pole and push the brush down the roof to tear the moss's shallow root system from the shingles. Do not brush up the roof as you might break the bond between shingle layers.
Note how the moss typically starts to grow at the top of the vertical slots between shingles. These areas of asphalt shingles are the last place water evaporates from a roof. Once the moss is removed, inspect these slots to ensure the colored ceramic granules are still in place. If the granules are gone and you see just the interior fiberglass mat of the shingle, your roof is well on its way to being replaced.
Green and black algae are not harmful to the actual roofing material because they do not develop roots. They are more of an aesthetic issue since they make the roof look horrible. Both of these algae can be cleaned from the roof, however the green algae is far easier to remove than the black algae.
It is wise to avoid chorine bleach as a roof cleaner. Chlorine bleach can remove the natural color from wood roofing shakes, it can kill vegetation on the ground if it runs onto the ground as it is rinsed from the roof and it can accelerate corrosion of metal gutter and downspout systems.
A better roof cleaner might be non-toxic oxygen bleach <http://www.stainsolver.com>. This widely available powder is mixed with water and applied to a cool roof surface, preferably on an overcast day. If you keep the roof surface wet with the solution for just 20 minutes and then lightly scrub the roof surface, the algae almost always comes off. Severely stained roofs may require multiple applications of the oxygen bleach <http://www.stainsolver.com> solution. The solution also helps to loosen the grip of the shallow moss roots.
Once the roof is clean you can hinder moss and algae growth by introducing copper onto the roof surface. Visit a roofing supply company that sells tin, copper and galvanized metal products to residential roofers. Often these companies sell rolls of copper that can be cut into long strips. I like to cut strips that are 5 or 6 inches wide and are ten feet long. Using a metal brake tool, I put a 20 degree bend one-half inch in from the edge on one of the long sides of the copper strip. This bend eliminates unsightly waviness that often develops as you cut the copper with a tin snips.
Place these strips of copper near the top of the roof. Slide the unbent edge up under a row of shingles so that the bent edge and 4 inches of copper is exposed to the weather. Each time it rains some copper molecules wash down onto the roof and create a poisoned environment that both the moss and algae dislike. Be patient as the copper eventually will turn a distinctive dark brown and then the classic green color. If you getting ready to install a new asphalt shingle roof, be sure to buy shingles that have copper hidden in the colored ceramic granules."
Old 1/13/06, 3:14 PM
That is some good stuff Joe... thanks greatly.
Old 1/13/06, 6:29 PM
Jae Williams's Avatar
For NWJon MAB is the Member Advisory Board
No one knows what they do, though. They skulk around in
the dark of night and do things.
Hey..I'm just kidding--maybe..,
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior 6 10/13/07 9:10 AM
How much does moss growth affect roof life span? fbartlo Exterior 9 8/1/07 6:31 AM
Ice Gaurd membrane dmacy Exterior 36 6/14/07 1:21 AM
Roof Repair? Maybe NO jhagarty Exterior 9 2/15/07 2:19 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
