Old 2/18/10, 4:44 PM
David C. Macy's Avatar
Default Multiple layers of roof
Could not get in attic, snow covered.
Can you tell from pics if bottom layer is slate or is it asphalt?
ID:	35054   multiple-layers-roof-154510-023-small-.jpg.jpg
ID:	35055   multiple-layers-roof-154510-021-small-.jpg.jpg
Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/18/10, 6:11 PM
James F. McKee's Avatar
Default Re: Multiple layers of roof
looks like slate from my office Dave....how old was the house?
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/18/10, 6:30 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Same here Jim, but I have never seen that before. Must be a real pain in the ***** to put asphalt over slate. Why would you do that? Seriously, I would like to learn something out of this one.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/18/10, 6:46 PM
I've never tried it myself but had a roofer tell me it was a fairly common practice....
Jim Mckee
Amherst, Ohio
Old 2/18/10, 6:48 PM
iniquette's Avatar
Strange, just seems like it would be more work than it's worth.
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/18/10, 7:04 PM
Built 1925
I have seen around here at least 6X.
Can you imagine the home owner, buyer, seller reaction when finding out when the had a roof leak or needed a roof tearoof and slate was under the asphalt?
Some over 100+ year slate.
Even though the garage was completly covered with snow I could tell this was done by a pro, you should see the roof structure, framing and roof drainage.
ID:	35067   multiple-layers-roof-154510-008-small-.jpg.jpg
Old 2/18/10, 7:08 PM
Jeffrey R. Jonas's Avatar
Nice ice dam/shield!
Old 2/18/10, 7:10 PM
iniquette's Avatar
Have you ever seen that Jeff?
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/18/10, 9:16 PM
Christopher Currins's Avatar
From here it looks like cedar shake or wood shingles with trim paint on it.
Christopher Currins
Certified, Licensed
Old 2/18/10, 10:19 PM
Yepp!!! Not that uncommon, actually. But I will say, that one was better workmanship than usual.
Old 2/18/10, 10:20 PM
Originally Posted by ccurrins View Post
For here it looks like cedar shake or wood shingles with trim paint on it.
I was thinking the same thing Chris.
Old 2/18/10, 11:42 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm going with wood shake. Edge just looks to 'smooth' and complete to have been slate. The breakage from nailing is terrible and should be showing as gaps here and there.
Unless the edges have no nails. And what else could you expect from an idiot that would nail shingles over slate? I've seen a couple of those. The broken slates and protruding nails cut through the shingles within 4-6 years.
Old 2/19/10, 12:13 AM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
comp over slate.......what comes up in my mind rigth off the get is slate is HARD so nailing comp down into the slate...that would be a son of a bit*h
Old 2/19/10, 12:15 AM
did you put your ladder up on the eve and touch it??? that would tell you what you had...my 2 cents
Old 2/19/10, 8:02 AM
Thanks Frank!
David, If you're not familiar with Frank, I consider him to be an expert on roofing.
http://www.albertsroofing.com/
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
