Grabbed my ladder, camera and spot light and decided to take some pics. It's not making sense right now but maybe some brighter bulb here can give me a clue. I guess I should take my the same advice I would give a client. "Have a qualified roofing contractor repair as needed" You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Ice dam?
You would think as I did have some last winter.
But the drip line was roughly 2 - 3 feet below the ridge of the snowy roof pic. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
sorry for your woes, bro'
appears to be right in line with your horizontal decking joints, bet the felt joint is also at this location and may not have the proper overlap ...ouch until the snow comes off a definitive answer will probably be unavailable i'd put down plastic/tarp to catch the majority of the dripping in the mean time to avoid further drywall damage ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
It has been unusually cold this winter and the roofs around here have been staying mostly white. There is plastic above the ceiling(at least partial) and you can see that some water has finally made it's way to the underside at the front and back of the garage. My other thought was that as it has been so cold and little sun(except when it was below zero) for the last month that I may have had some frost on the underside of the roof decking that melted in today's +40 and sunny weather. The garage door pic show the extreme frost build up at he seems that has been there for over a month with no melting until some today. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Did you have it inspected before you bought it? If so, sue the home inspector!
All I had this morning was a friends rent house small electrical problem, so I rode my Cub Cadet for about an hour and my yard looks great (over sowing with Rye late Fall helps)
Not being a Northerner (obviously) could it be ice/snow melt at the ridge vent that ran down and then dripped from a low spot??? Serious WAG, just throwing it out there... Barry's felt paper idea sounds better. Sorry for your troubles Michael, educate when you have it figured out... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Chrs,
Those are wet spots. Mke, Good thought but no ridge vent. Square vents on the back side of the ridge. Joe, I don't think anything was missed. I hope to know more after a more thourough look. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell Last edited by mlarson; 2/1/09 at 11:32 AM.. |
Ahh, I see in pic 5 (after looking again) it's just the cap shingles I can see...
I guess ridge venting with the accumulations of snow could be somewhat contraindicated... - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
Mike
all those spots , it wouldn't happen that the nails where covered with frost when it was cold and now melted? |
I know they're wet spots. I was suggesting maybe a few of the nails have backed out. It is common, especially in extreme change in temeperatures. It doesn't take much to leak.
It was above freezing today but no more dripping ocurred(at least not when I looked). I am starting to convince myself that frost on either the roof deck or nails may be it. I think stack affect comes into play here as the sheet rock seems in my garage ceiling are not taped and mudded. There has been excessive frost on the garage door seams and I'm thinking stack affect also pulled moisture laden air through the open ceiling seems and condensed on the deck and nails. Perhaps I have a bypass from the interior that is also contributing to this. I sure wish I had a IR camera. If I have time tomorrow I'm going to walk the attic for a closer look and to check for any bypasses. I have a large number of recessed down spot lighting fixtures but from what I could see yesterday they are well buried under blown in insulation. I inspected the roof last fall (it's 8 years old with architectural type shingles. I had a loose shingle on another part of the roof that I nailed back in place. It appears to have been missed when it was nailed and the seal tabs had not adhered. Unrelated issue. Barry, I'll take one up the ladder with me tomorrow. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
| Roof type & excessive leaking | dmacy | Exterior Inspections | 7 | 9/12/06 12:07 PM |
